Xray NT1
#616
Originally Posted by RoNTC3
Is it just me or is this thing Identical to the RRR? I'm not looking to start S#!t as I have been waiting just as long as everyone else here for it to come out. I just built my RRR a month and a half ago and I must say I think I could have built my RRR with these Instructions....They look that close to me
Now fire away at me........
IMO, it's a cross between a RRR and MTX-4 - taking the best of both, improving on each's shortcomings, adding some goodies and turning it into one fine nitro touring sedan. If you go through the MTX-4 manual (click here), you'll see why it's a little of both.
Just remember, when it passes you at the track, it's your driving. JK!
#617
Originally Posted by bvoltz
I'm the only one that can not print these documents out? If you have figure out how, please share with me...
#618
Suspended
Originally Posted by rmdhawaii
...Setup book has some great info - but it doesn't seem to mention anything about front/rear tire split or running small tires for qualifiers...
#619
Originally Posted by AddictedToRacin
Hehe, just use MacOS X. I printed it yesterday without any problems
Interesting... I have a MAC in the company, so maybe I can get them to print to my color printer.... I just like having my book with me... Which has all my manuals in it and setup sheets, and tips... etc....
Thanks...
#621
Originally Posted by GK
Here you go, I made a quick overdrive chart...
For completeness, it would have been good to include an explanation of tire split and why you would want to run smaller tires for a qualifiers. A separate booklet on tires and tire strategies would be awesome.
#622
I did find something in the quick reference table booklet, but not quite what I was looking for...
When using the 25T mid-side pulley:
If you use the 25T mid-size pulley, the ODR ratio is 1.04:1 (based on gearing ratios alone); the front wheels rotate 4% faster than the rear wheels.
When you start racing the car with rear tires that have a larger diameter than the front (for example, a 2.0–2.5mm difference), this tire size difference will neutralize the ODR and the car will be balanced with no push between the front & rear wheels.
However the rear tire wear is usually higher than front tires wear, which means that after some running time the diameter of front and rear tires will get equal and then the front suspension will start to pull (the rear suspension will brake the car).
#624
Suspended
Ok, let ask a newbie question. I got the Over Drive Chart and printed it out. But what are the keys I'm looking for? 1.0xxx
I'm asking how do you use this information...???
#625
Suspended
Originally Posted by Green Machine
Hi Guys , I just got my NT1 any tips or advice you can offer before i start the assembly process would be greatly appreciated.
Cheers
Rob
Cheers
Rob
From other xrays I've built (electric TCs), I would start with shocks - they use the same in NT1. Make sure you build the adjustable ones, fill them up and let them sit overnight if you can. Be patient when you bleed them. Good instructions are here, second post from top.
Other than that everything fits perfect, xray makes best molded parts in the industry, no need for dremel tool
#626
Cheers
Rob
Cheers
Rob
I am in long, long waiting list...
Where did you get it??
I want one!!!
#627
Originally Posted by gtrmx
What is this? Are you trying to make a few of us jealous!!!
I want one!!!
I want one!!!
Take Care,
Cheers, Patrick
#628
Originally Posted by Saint728
We had 4 in stock yesterday, but sold 3. I might have to build the last one myself?
Take Care,
Cheers, Patrick
Take Care,
Cheers, Patrick
#630
Yeah, we're the first in the World to get them. I'm sure the rest of the World will get theirs soon too?
Take Care,
Cheers, Patrick
Take Care,
Cheers, Patrick
I have my XB8 EC for more than 2 Weeks now and the NT1 should be already out to the customers and i know that some ppl are driving them right now.
We have good weather here in Europe.
