Losi 8ight building and setup
#3061
Originally Posted by PTP Racing
Amainhobbies.com has it listed
Silver 0.040 30 degree
Gold 0.040 25 degree
Black 0.036 30 degree
Green 0.036 25 degree
No offense to the Drake but I take the word of a business over an internet post. Ive made plenty of mistakes when posting.
silver, gold, green, black.
If you look at the part order on the losi site they're listed in that order as well (but unfortunately without the specs).
#3062
Anyone know where I can find some of the aluminum bearing inserts - LOSA4430 - in stock (or anyone have a set they want to sell)? I'm having some major problems with my rear diff and want to rule this out as a factor.
Thanks,
Shane
Thanks,
Shane
#3063
I'm going to check when I get home. If your right that sucks because I ordered the wrong ones.
#3064
He's right.
#3066
I was wondering if a flat 5 cell 2/3 reciever pack will fit in the battery box or will I need to reconfigure my packs for when I get my 8ight?
#3067
#3068
I thought I could trust Amainhobbies.com I use them for part numbers and stuff all the time and this is the first time they've been wrong. Oh well I think a green and gold combo should work just fine. Or like you said the kit has extra springs I could use the pair of blacks.
How long does the stock clutch last with the 14t bell? I bought a 13t and a set of kingheadz shoes for when it does finally go. Ive put 3 tanks on it in my neighborhood to break the engine in slightly and I am going racing Sunday. I wanna know if I am going to need to replace it before the main. I could have to bump up if things are the same as opening day last year.
#3069
Stock clutch should last well over a gallon, though you should check it now and then and make sure the aluminum shoes don't mushroom too much and catch against the flywheel.
The bell should last quite a bit longer.
#3070
Spring Rate Chart
Originally Posted by Kcdzim
Seriously man, you don't want to take that road. I'm still washing the egg off my face, and I argued stubbornly for amain (and bmain). Carolina RC has them confirming Drake, and quite honestly, Drake pretty much speaks for the business as he WORKS for Losi.
So I am going to go with the Gold and Black combo.
#3071
Originally Posted by glitchy
It's a pretty small battery box, 2 over 3 and small lipos are about all that will fit. The 1 over 4 humps won't even fit.
#3072
Originally Posted by JWRockman
I called and spoke to Josh today to verify. I have spoken to Josh before and he is good. Anyway, he told me he took the clutch spring rates directly off of a report from Adam Drake and cut and paste the information.
#3074
Miller- If you worry anymore your going to have to check into therapy. Just run the silver and black springs, silver on the aluminum and black on the carbon. Ive got three gallons out of a set of shoes. If your worrying about them being done before a main, or they do wear out in a day, something is definetly set up wrong. Ive been running the car for about 4 to 5 gallons and have got my 2nd clutch in it.
#3075
To those of you running radio tray stiffners - are you then having body mount problems? My throttle linkage rubs on the body because it sitting up higher. There is no adjustment in the body mounts to speak of either. Any suggestions? This is with both the JConncepts body and the Proline.
