Team Losi JRXS Type-R
#9436
Trader Rating: 7 (89%+)
I want to rebuilt my diff on my losi type R.
Could someone let me know if the thrust bearing #3098 will fit or should I really go with the #3018
#9437
Don't use the losi ones. Go for the XRAY AXIAL F3-8 bearings used in their models. Awesome.
#9438
#9439
the corally ones work also, or the axiom ones are nice.....
i am not a fan of the losi thrust....the cage continually breaks...
#9440
Well, I found the rear carriers were mounted on the opposite sides on my new to me car. They are the 1* blocks. I've swapped them and now have 3* rear toe on each side. The car did come with the stock 0* carriers and I also picked up the 0.5* blocks from my LHS while I was at it. I haven't tried it yet, but the funny thing is, the car drove really well with them reversed. Rear toe would only have been at 1* on each side with -1* per carrier. Under what circumstances would having them reversed make sense?
#9442
#9445
Location: Colorado, USA, The land of the free and the home of the brave!
McMaster is the KING of hardware. If you need it, most likely they have it. I also reccomend the mcmaster thrust bearing, though they are a bit pricey, especially if you need to order only one bearing.
#9447
#9448
http://www.axiommotors.com/ceramic-t...ssy-p-470.html
Paul Lemiux claims they are the best he has ever ran, along with Mr. EA himself!
http://www.axiommotors.com/customer_testimonials.php
#9449
Ours are 12.95 ea and come with ceramic balls in a nice hardened cage (I had these specially designed for RC), add another set for 50% off.
