Team Losi JRXS Type-R
#9421
I drove mine for the first time last night and its very neutral. I'm not pushing the envelope of speed and handling just yet with the 13.5, but it looks good and is very predictable. I'd say I'm a second or more off pace with the experienced drivers at our track, no big deal as I'm in learning mode. It came with a setup on the car which needs to be documented as the shop owner who also drives a Type-R wants to compare with his setup. We'll see if its ready to race this weekend (if I am actually). I'll post the setup it has on it for giggles once I have it.
#9422
Hoping someone could help me out with the final drive ratios for the Type R, looking to go to the optional 41t pulleys to lower the ratio. I am trying to lower for the use for a VTA, and cant get my hands on the JRXS spur adapter. I am also running the 17.5 4 cell spec. Any and all help will be greatly appreciated.
#9423
The internal drive ratios are
42/23= approx. 1.83 Stock
41/23= approx. 1.78 With 41 pulleys front/back
You will probably still have a hard time gearing a 17.5.
As for finding a spur adapter, I would try 360. www.360rcspeedway.com.
#9424
looking for a little help myself....run rubber tire on low bite ozite carpet.basically running haynes sppol set-up except im running 17.5 springs on the front and back.i also put a 1 degree rear block on it for more steering.
car pushes badly coming in the turn...but exit it has way to much...any help..?i dont really know where to go with it.i was told that the rp24 tires i was using were shot...tires might be the problem but i dont know...lmk
#9425
#9426
any comments on how to get more off power steering.even using the 2 degree rear block it still pushed pretty bad.i have the shocks all the way down in the front.before i put the 1 degree block in the rear i tride them in the middle hole.but made the car loose in the middle of the turn...
i got one week left to try for they are shutting down for the season..and well there is somebody there who needs to be tought a lesson.....lol
#9428
traction compound im using trinity zip free...i think thats what its called...they only use a couple different traction compounds there and one was jack the gripper and that zip free.
again thx for the help.
#9429
im either going to buy the sorex 24 or 28.im hearing the 28 tire is the better choice.
#9430
Good Luck,
Casey
#9431
makes sense...thx....i knew it would help with the steering.i just didnt know which way..lol..
