Team Orion 3200mAh Race Spec LiPo
#376
Can I charge my lipo pack right after the run while it is hot? Is that going to decrease the performace and life?
#377
Either way, I have hundreds of runs on mine and they still kick ass.
We just used them last weekend for the Enduro at Tamiya and we were getting 15.5-16.5 minutes with a pretty serious Hacker BL setup and they weould take 4200-4300 on the charge...so they weren't even dumped yet. I bough them from the very first batch when they first came out and I run them nearly every week.
#378
#379
I also agree.
I am running two of these (1, 5 min practice & 3, 5 min rounds).
The Lipo comes out of the car warm only and goes on charge straight away, by the time it is charged it i s cold.
These bats are cheaper and a lot less trouble than Nimh (Only need 2 packs not 4), fit in my xray fk05 with only a slight change and with the time I save not having to maintain them it got to be good for the hobby.
#380
I run LiPo's as well (see my signature). 2 packs between 3 cars. I will be getting a balancer too as soon as one is available.
Not having to maintain the packs as you do with NiMh is the real plus for me at club meets.
#381
You dont really need a balancer as long as your charger can do single Lipo cells.
#382
To balance them on an ICE, just change the voltage to 3.7 and charge it with the (+) and center post, then the (-) and the center. Whichever side of the battery you're charging, just use the opposite polarity lead on the center post.
All you're really doing is charging the cells individually.
I just did mine for the very first time...one of the batteries (my oldest one) took maybe 100MaH more on one side than the other...but the other two batteries were all within 5-10 Mah between the sides.
Mr. Black: How does a LiPo charger sense that the battery has reached capacity?
#383
You'll also need this for the balance port - 2mm plug
Got mine in but it's only told me I don't need to balance yet.
You'll also need to alter the connector from the balancer like in the attached image that I stole from Mr. Black from a few pages back.
#384
#386
Thanks for the quick answer guys. I'll probably cycle mine after 100 full runs. Its because I'm just noticing that my lipo in my heli is going down in runtime when I dont balance. Haven't noticed any changes to my platinum lipo yet.
To be sure again. The balancing port can accept + and - from ice.
I connect the lipos positive terminal to my Ice's positive wire and connect the small plug to the Ice's negative wire and charge at 3.7amp. After finishing that cycle I connect the lipos negative terminal to my Ice's negative wire and connect the small plug to the Ice's positive wire and charge again.
I saw the wireharness and the mods you have to make I dont think I could get that kind of stuff in my lhs.
#387
Sorta...the connection part is good. It's basically two batteries in there and the balance port is the connection between them. They're arranged (+ - * + -) with the "*" being the balance port at the connection between the two cells.
Just change the voltage to 3.7v That's only one click less and reflects the voltage of the individual cell(s).
The charge current will be the same (4.8A).
#388
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
balencing
MrBlack
spoke to mirage 2 things they suggested
1)try re balencing
2) shove it in a freezer over night
balencing
is there a machine for this ??
or just shove a metal bit in port !! & charge it
i`m going to volt meter tonight @club
1)try re balencing
balencing
#389
#390
[QUOTE=MR JOLLY]
balencing
Yes - http://www.teamorion-avionics.com/Ce...lancing+System
You will need to do this to it:
