Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
O.S. .12 TZ(P)-T3 Speed Tuned >
Old 04-08-2007, 10:56 PM
  #136
uniquexme's Avatar
Trader Rating: 12 (100%+)
well, few months ago, i polished my whole engine inside out. keke. its save if u are just polishing it with cloth and autosol. dun feel much difference, but just looks more shiny.
btw, can some1 help me with the mixture needle factory setting?
uniquexme is offline
Old 04-10-2007, 05:02 PM
  #137
HIGH SPEED NEEDLE 1 3/4 TURNS OUT LOW SPEED 1 TURN IN FROM FLUSH
TOP END SHOULD BE REAL CLOSE WITH THIS SETTING,LOW END SHOULD BE A LITTLE RICH,ADJUST WHEN YOU RUN THE CAR
GFIGUEROA is offline
Old 04-10-2007, 05:22 PM
  #138
uniquexme's Avatar
how about the mixture needle??? thats the most important of which i want. thanks.
Old 04-11-2007, 05:55 PM
  #139
Trader Rating: 15 (94%+)
midrange needle is flush with the carb body
ive never had to touch any mid range needles on my tz engines
mrgsr is offline
Old 04-11-2007, 05:57 PM
  #140
Default clutch setup with rrr and os speed tz
hi guys
i just wanna get some info on how you guys set your clutch up on the rrr with the os tz
currently i set my clutch adjusting nut to 1.2mm and i have about 0.4mm of gap.
how does this sound?? i race mainly on a high grip track.
thank you
mrgsr is offline
Old 04-11-2007, 06:36 PM
  #141
IF YOUR REFERRING TO THE NEEDLE WHERE THE FUEL ENTERS THE NIPPLE THATS YOUR HIGH SPEED NEEDLE
Old 04-11-2007, 07:06 PM
  #142
uniquexme's Avatar
i m not refering to HSN, i mean the mixture needle, on the carb, behind the LSN.
Old 04-11-2007, 07:22 PM
  #143
JUST KEEP IT FLUSH WITH THE CARB BODY. HOPE THIS HELPS
Old 04-14-2007, 06:49 PM
  #144
ok guys i have this motor and i am planning on running 20% nitro, what shim setup/plug setup should i use?
Trilordy.com is offline
Old 04-15-2007, 03:51 PM
  #145
stock shimming is fine for 20%,stock plug #6 is great.if track you run on has long straight(over 100 ft) go to a #7 plug.try to stick to os plugs,they may cost a little more but are well worth it
Old 04-15-2007, 06:51 PM
  #146
Thanks GFIGUEROA, yeah i know i always run the O.S plugs they do seem alot better!
Old 04-16-2007, 08:49 AM
  #147
vc05hdt's Avatar
Is it typical of OS motors to have what appears big end of conrod play? A friend brought a brand new OS TZ to the track and showed a few of us this motor and at TDC rotated the shaft and it looked like about 10 degree play/slop. A few have snapped rods after run in not only TZ.
vc05hdt is offline
Old 04-16-2007, 01:22 PM
  #148
terry sturchio's Avatar
I know the OS engines seem to have a really tight piston/sleeve. Seems like if you aren't careful about the break-in, it could be very hard on a conrod. I don't think I would use the WOT on this engine. I have mine here new and it's really tight. I will definitely be heating it up with the gun first.
terry sturchio is offline
Old 04-16-2007, 01:28 PM
  #149
THE OS NEEDS ABOUT 12-14 BREAKIN TANKS BEFORE THEY LOSEN UP.I'VE HAD 3 OF THEM AND LOVE THEM!JUST TAKE YOUR TIME BREAKING THEM IN AND YOU'LL BE FINE.
Old 04-16-2007, 06:15 PM
  #150
vc05hdt's Avatar
Thanks also for reply Terry. This engine was brand new and no fuel through it, straight from the hobby shop. Excessive play doesn't make sense to me. Is it normal for OS to be like that with their higher spec motors? Also 12 - 14 tanks run; in how many tanks life left in the motor with your experience after good run in G?
vc05hdt is offline
