LRP Pulsar compeition charger Problem! anyone else?
My charger can only charge at .6 amps.. i dont know what happened and i didnt let the smoke out. Supply volts is 13VDC and the internal fuse is good.
The display flashes "Inp-low" where the amperage is indicated. Has anyone experienced this problem? Help!
thanks in advance
thanks in advance
I have experienced it once when using a crappy PS. But I have not seen it since buyin my 25amp PS from Radio Hack.
when it says input low the power supply cant punch out atleast 12v DC power. time to change P/S unit
both my pulsar and pulsar 2 will display that error message if I charge my transmitter battery. No problem at all for 6 cells nimh or nicd. If your power supply has voltage selector, crank it up to the max.
