Intellect 4200SHV >
Intellect 4200SHV
Intellect 4200SHV
Old 06-12-2006, 08:59 AM
  #61
Hi,
I tested 4 packs of the IB4200 SHV this weekend and it was very impressive.
Runtime seemed to have no end. I discharged between 1300-2000 mAh after 5 minutes... in Modified. I ran a GM Brushless system and had for the very first time problems with a thermal shutdown. On the one hand this was because of the weather but the extremly high voltage of the new IB's was another reason for it.
The performance was really good. I didn't tested the capacity of the packs but I was able to charge up to 5000 mAh into the pack. This is absolutely amazing...
Cheers
Chris
speedy-932 is offline
Old 06-12-2006, 09:25 AM
  #62
AdrianM's Avatar
The batteries are so good everyone at the World's practice in Italy this weekend was melting speedcontrols, throwing winds (Brushed) or thermaling speed controls or fragmenting rotor (brushless).
A few cars melted speedos at the end of the straight and continued at full speed into the a wall
This year the worlds will be won by whoever can complete a 5 min run without frying their electronics...not the best driver or the fastest car.
AdrianM is offline
Old 06-12-2006, 10:31 AM
  #63
or those who make the better cooling system!!
canto54 is offline
Old 06-12-2006, 11:29 AM
  #64
And then they went pop ....
Andyg01 is offline
Old 06-12-2006, 11:45 AM
  #65
Hi,
no... If you don't believe me, I can post pictures of all 4 packs... ;-)
Cheers
Chris
Old 06-12-2006, 05:58 PM
  #66
Shop Owner
nnick's Avatar
Originally Posted by Danny/SMC
We have seen a need for a bit different motor setup with SHVs due to the extra power but I have yet to hear speedo issues. I personally think that the cells are getting close to the voltage limit but then again if someone would of told me last year that 1.22s would be available in 12 months I would of not believed it.
What kind of motor setup is recommended to use with the new SHV batteries?
Nick
nnick is offline
Old 07-07-2006, 05:08 AM
  #67
Echoing the question nnick had. It would be really good if you could post some info on what we should do differently with our motors.
Less timing?
Lower current brushes?
Softer springs?
Brush cuts?
Lower ratio? By how much?
Lower ESC brake settings?
Less aggressive ESC throttle settings?
Cheers,
Tim.
THancock is offline
Old 07-07-2006, 11:52 AM
  #68
Originally Posted by RC-Connect
The numbers are insane, voltages of 1.224 to 1.229!!
Here in Europe, we have 1.245v cells with the same discharge amps
However, factory drivers recieves cells 1,300v + though....
Jan Larsen is offline
Old 07-08-2006, 01:42 PM
  #69
ottoman's Avatar
Trader Rating: 13 (100%+)
1.3 volts at 35 amps with a .09 cutoff? Somehow I find that very hard to believe I will ask Paul Lemieux this weekend what numbers he was running at the worlds
ottoman is offline
Old 07-08-2006, 01:58 PM
  #70
X2
X2's Avatar
My freind bought 3 packs of Orion 4200shv's.
They seem impressive but the numbers are a little hard to compare because they are discharged at 30A.
There wasnt a great deal of difference between his SHV's and the normal cells, but there was a difference however small it was
X2 is offline
Old 07-08-2006, 02:35 PM
  #71
ottoman's Avatar
Well he did say "with the same discharge amps"
ottoman is offline
Old 07-08-2006, 03:57 PM
  #72
Just keep in mind that SMC is one of only a few companies that show real numbers on their cells.
RC-Connect is offline
Old 07-08-2006, 04:21 PM
  #73
Team EAM
Trader Rating: 79 (100%+)
I would NOT agree with that. 99% of all companies out there show real numbers. They just use different systems to get the numbers. Orion's RDS system is a PROVEN system....Hell they just put more cars in the A main at the worlds than anyone!! Its just not the same as standard CE Equipment that SMC, Trinity, and others use. Reedy uses something along the same lines as the Orion system.
They are not faking any numbers....They are just being matched a different way and showing numbers a different way. Which in the real world can confuse a LOT of people but it doesnt mean they are lying about anything.
EA
EAMotorsports is offline
Old 07-08-2006, 05:50 PM
  #74
wallstreet's Avatar
Trader Rating: 24 (93%+)
And you know this how ?
Dont make statements you cant provide correct data on
wallstreet is offline
Old 07-08-2006, 07:05 PM
  #75
RC-Connect is doing distribution of SMC battery in the Netherlands. That 's why
caveman is offline
