Serpent 720
#781
hey come on more pictures please
#782
i had a very big crash on sunday Today i had time to look at my car the front bumper is damge the lower wish bone has a crack . my pipe is damage
#783
(it has its own sleeping basket and lots of toys but apparently my toolbox is way more interesting...)
#784
(and you haven't been in a big crash until you actually bent a crankshaft as I did )
#785
Originally Posted by Qlone
Ok, here's a picture of one of my mechanics...
#786
what a mechanic. i have me myself and i.
#788
WHO'S GOING TO GREAT LAKES CHALLENGE
guys' im going to greatlakes challenge any advice especially on gearings and set-up
Thanks a lot'
Thanks a lot'
#789
Originally Posted by rcpanama
You could do that if they are NiMH, but even though they do not create memory as the NiCad, they do in some way, also if you don't recycle them (discharge & charge), they in time will decrease in capacity.
I deal with a battery pro who only does batteries and nothing else. Sells 'em, packs 'em, even contracts a factory in China to make 'em. The guy tells me over and over, don't cycle the NiMH batteries. These batteries are made not to be cycled and do not have a memory effect. Cycling is not required. It doesn't damage cells but a quality cell is only good for 500 charge iterations before the cells starts to die. Cheaper cells won't last 500. The best advice on NiMH batteries is that they are very sensitive to heat so over charging them has the potential to shorten their life as well. I typically charge my Sanyo AAA 1000mAh packs at .8A to 1.0A. If I have the time, .6A
The other factor to keep in mind is that all battery chargers are not equal. Some are a lot better than others. I've seen 'dead' battery go to 'live' battery just by adjusting a charger's settings or using a different charger. Lower priced chargers tend to cut out during a false peak and have no way to get around this problem. Typically chargers measure the output voltage of a cell during charging and once the cell reaches the typical 1.2v, charging will stop. A false peak is when the cell puts out 1.2v but is not fully charged. Some chargers can be told to ignore the false peak and keep charging.
If you notice your batteries are consistenly undercharged, your charger may also be part of the problem.
#790
Originally Posted by Maxx
Do you guys discharge your receiver packs before you recharge them or you just throw it on the charger after you take it off the car?
Hey Acid what is that you use over the fuel tank? I guess its there to keep fuel from splashing all over the car during refueling right?
The bateries, well I discharge first - suppose to help with keeping the charge for a long while. I use digital servo for accel/brake and hi-torqe analogue for turning.
The stuff over the fuel tank is a piece of high absorbption cloth, nothing special. Go to convenient store and you should find it in the cleaning agents section, not expensive at all. By now you would have read about all the problems guys have with electrics - so, I figure why not protect against fuel spills during pit stops Only down side, it costs you in weight, prob around 10 grams.
Acid
#791
personal transponder location???
"where are you all mounting your personal transponder???"
have any of you tried to see if the "new" 960 steering servo mount "fits" in the 720 ???
http://www.mytsn.com/products/desc.asp?prid=4273
#792
#793
http://www.rctech.net/forum/attachme...hmentid=156087
#794
More Info
Originally Posted by Julius
I have it on the place it was designed to sit. On the front downstop plate.
Julius, which is the down stop plate - the new nose?
Please see pic....
Acid
#795
Info
Hi Guys
Does anyone know how many teeth the standard rear gear diff for 720 has? The one that comes with the kit.
Acid
Acid
