If Hudy or AMain made a $120 dollar premium electric screwdriver, would you buy it?
Features could include:
Aluminum Construction
Steel Gears
Brushless motor
Proportional trigger
Replaceable 18650 Lithium battery
USB charge port
2-speed gearbox (up to 1000rpm)
10 step mechanical torque control clutch
Electronic torque control
Twist (Gyro) Activation (as an alternative to using a trigger)
Elbow Pivot to switch between gun and straight grip positions
Heavy duty bearing supported output.
Optional Rubber grips
Compact size ( about 1.25"[30mm] in diameter and 8"[100mm] long)
I started designing one in CAD and looking at parts to make a prototype
and I wanted to know, if it was a premium quality product, would anyone be interested.
I will post a picture of what I have designed so far a little later.
Please feel free to suggest additional features.
Steel Gears
Brushless motor
USB charge port
Last edited by benben10; 01-23-2018 at 11:47 AM. Reason: Added Extra Feature ideas
Steel Gears
Brushless motor
USB charge port
Steel Gears
Brushless motor
USB charge port
I am thinking a 3.7V 3000mAh (or greater) battery. Something like a SAMSUNG 18650 3000mah Max 15A INR18650-30Q li-ion Battery
I would expect all parts to be replaceable.
More choice is good, but market is covered well by many companies.
Power tools are only good to strip threads, unless you build kits for a living I don't see how useful would it be.
I make do with a Bosch Ixo V, it was like $40 and doesn't even have selectable speeds. $120 would be waaaaay too much.
It would need to be as small as the MuchMore driver and have all the bells and whistles you mention. Otherwise I wouldn't part with my Ryobi tek4 for it. But having mobility issues myself anything to aid in the wrenching process is a blessing so if it's doable I'd buy it
I have a ryobi tek4 as well but the newer models have removed a lot of the features. Everytime i go to Lowes or Home Depot i dont see anything that matches my old tek4. I was lucky to find a single extra Tek4 battery that was marked for clearance. I am aiming for something about the same diameter as the Muchmore just a little longer and with an adjustable elbow.
the 53L was the nice one. The newer one is a 54L. I left my old one in a customers apt. They are like,nope, never saw it.......liars.
My fault for leaving it there though.
But to answer the op's question, no way in heck would I spend that much for a hobby screwdriver. I have a Hitachi 12 volt combo driver and impact driver with 2 batteries and a case that was $99 on sale at Lowes.
