Hpi Pro 4
#6032
How often do you guys clean your bearings? What do you do to clean them?
Cheers,
Mossie
Cheers,
Mossie
#6033
Cheers,
Mossie
Cheers,
Mossie
#6034
thanks man, how do you clean them? I havent cleaned mine yet and ive been driving my car for 5 months
Cheers,
Mossie
Cheers,
Mossie
#6035
RPM make a tool (bearing blaster I think it's called) that you can sit the bearing in and shoot motor spray into and it will blow the dirt out. I use a tool from Integy called the Indi Sparkle Parts cleaner. It's powered by 2 AA batts and it basically vibrates to shake dirt out of the bearings. Works pretty good.
#6037
#6040
Originally posted by Ralf
Guys,
I need your point of view, I plan to buy some ceramic ball bearings for the Pro4
Do you think it is worth buying them as the price is rather expensive...
thanks for your input
Guys,
if you're racing competatively then it may be worth the extra money.
#6041
The stock ones are pretty good already. Just make sure you clean them frequently to keep them rolling smoothly.
#6042
Hey guys, I wrecked last night after a few tumbles with the car and then smack right onto the boards.
The aftermath:
The "potential" fix:
I know it's a bit off center but it's just a prototype. I had an old Kyosho V One R that I sold about a year ago. And I kept the Lola Body Bumper set. Took the bumper and trimmed it a bit. Then drilled two holes big enough to fit the body post base. I'll let you guys know how it does this Sunday.
The aftermath:
#6043
Dude, are you sure that thing won't poke the other cars? Cut the ends off man!
#6044
It fits under the body perfectly.
