tunning vspec
tunning vspec
ok guys i have a vspec and running it with the jp3 pipe im temping around 210ish but it doesent realy rev very well at the top.i noticed the idle gap was to wide o i have set it to .5mm per the manual i need to run it again but any help or hints greatly recieved as i like this motor
cheers in advance
cheers in advance
Spud, start here:
2 1/4 out from closed on top
3/4 in from flush on bottom
mid needle flush with carb body
Then lean the top till it is good, then bottom at idle once its up to temp, lastly set the idle gap if its too high or low.
cheers guys will try that tomorrow
