TLR 8IGHT E 3.0 THREAD
#1082
6s Ben! 1500-1700kv I imagine.
#1087
#1089
Look at part numbers on both the manuals. See what matches otherwise it's different. By the time you buy everything you most likely spend as much as the buggy cost. My advise would be sell your 2.0 and just buy the 3.0
#1091
Point taken JasonR/C but many of us out there are budget guys who just like to have fun. If I had the money I'd totally buy the kit but at $650 it's not gonna happen. If I can do the chassis and some of the chassis parts for $150 I'm gonna do it.
That being said, who can actually answer my question? Will the 2.0 front and rear end mount onto the 3.0-e chassis? Thanks.
#1092
#1093
It will mount but not without issues. You will need the new droop screws or the old ones will quickly tear up your chassis. But the new screws only fit the new arms. And the new arms only work with the new uprights. And the new uprights only work with the new spindles....starting to see why everybody is saying to just get the whole kit? I didn't even mention the center bones. No way your gonna be anywhere near $150. Just the chassis and body is about $130, then you need motor mounts, batt tray, servo mount, etc....
The 2.0 is a great car. If your on a budget, then just get the new shocks and standoffs. That will help a lot more than the chassis.
#1094
#1095
Ben I would suggest you try silvers with a 2.5 bar (if still running a 2.3) or standing the shock up on the tower. As a last resort cutting a coil or 2 off of the silver will give you an in-between. I have not done this in a long time but cutting coils will make it stiffer.
