TLR TEN-SCTE 2.0 Kit Thread
#3361
I used a power screwdriver with a screw to pre thread the holes, go straight in in one constant drive. using a hand held driver is a lot of starting and stopping and angle changes which doesnt help.
did six diff cups with only one screw and didnt have a problem.
The only issue with getting a tap is its really small and if you break it off it might be a problem to get out... Murphys law states that it WILL break off inside where u cant get at it. again if you do I would chuck it in a drill, NOT the hand tap handle.
#3362
NOT an issue, after tapping the screws are still very tight going in...
#3363
did any1 try MIP's 41 tooth spur gear?
#3365
what i meant is - will it fot to the chasi? i recall a fotting problem with kingheadz chasi
#3366
I think cutting a slot thru the hex is just asking for it to fail.
I burned myself on a screw backing it out with a power driver from the friction generated heat. Even screwing it in manually, I could feel heat build up.
I'll do it for the next ones I replace.
#3367
Tech Prophet
If I was tapping metal holes that deep I might be worried about a broken tap, but in plastic I've done holes much deeper than these diff cases without problems.
#3371
She sounds OLD!!!
Ok....im probaly 10 packs through my truck....ive ran half on indoor clay...half on outdoor dusty/loose....every time its been ran on the dusty surface it has been blown of with compressed air.....i ve tried to get every nook and cranny....however....the front steering now creaks like an old lady....both directions slow or fast....is it the captured ends?? I've never heard an rc truck make this noise this quick....
#3372
#3373
Just shortening wires to finish the castle 3800 race pro
I have heard that some motors wires can't be cut does anyone know if this
Is true for this castle motor?
