Hpi Pro 4
2 cheap ways to get faster laps.
1: practice and do NOT hit anything.
2: work with setup.
Both cost nothing. Other then that you will have to spend money on stuff that will do nothing if you dont master the first 2 listed above.
2: work with setup.
Originally Posted by wannabe_racer
ok, this will be my first time into on-road racing, ive got a traxxas bandit that i bash, but would like a good rc car, that comes with most of the stuff needed, (MSC/ESC, Motor, Body, Electronics) is the Pro 4 good for that (seen that it doesnt come with lots of gear) or should i get these:
http://www.southeastrc.com/Items/Std...ookup=LOSA0255 (Not sure if comes with gear)
http://www.southeastrc.com/Items/Std...ookup=ASC30110
(Was looking at that before
or get the cars that the blokes at the track use?
Thats all, any good offers are welcome
Originally Posted by kyracer
buffing the glues? Hmm what polish would you use to smooth out the glue surface?
I have some old foams and will try shoe goo and epoxi on to see the results.
I was thinking epoxi with less harding.
Just use CA glue (preferably Proline's thin type) on the sidewalls. Apply a coat to your new foams, straight from the box . Let it dry, then, apply one more. Allow the tires to dry, then, true them down to your starting size on a tire truer and use a file to round the edges and give the tire a low profile. They'll have a nice hard ring right below the tire's edge.
Thanks dawg, I done some test and it seem that CA glue done the best. The 2nd coat after drying is a great idea.
Should I use a spool or one way for this new track?
pics http://www.rctech.net/forum/showthre...page=316&pp=30 Post #9466 Post #9475
video of the track http://rapidshare.de/files/11926191/Mvi_0957.avi.html
Thats not me driving btw. local racers driving.
New to this stuff and was wondering was hop-ups does the hara have over the regular pro 4?
That's not me driving btw. local racers driving.
I think the Hara has:
Included Spool
Delrin outdrives
Modified top-deck
Alu servo mount
Updated motor mount(open ended)
Alu spur adapter shaft (now one-piece)
Improved diff nut
Upgraded shocks(fluorine coated)
hope that helps..
Included Spool
Delrin outdrives
Modified top-deck
Alu servo mount
Improved diff nut
hope that helps..
Hara Edition Pro 4 features:
* 2.25mm upper deck provides more grip with the same front to rear stiffness for improved track performance. The included cone washers and o-rings improve chassis durability.
* Competition aluminum threaded shock set with fluorine coated shock body, new smoother o-ring, and new pistons provides extra smooth action for improved suspension performance.
* Precision machined aluminum servo mounts for extra durability.
* Heavy duty, self lubricating ball cups for increased strength and smoother suspension movement.
* Included Front Solid Axle Set (spool) for more stable acceleration out of corners and during heavy braking. Precision machined from light weight aluminum for quick acceleration and higher top speed.
* Additional set of pivot blocks and spacers provide a wide range of tuning options to accommodate different track conditions and layouts.
* Integrated differential nut design adds strength and prevents the differential from loosening up.
* Delrin outdrive set to reduce drivetrain friction for higher performance and increased efficiency.
* Machined aluminum motor mount with open ended design for easier motor installation and removal.
* Precision machined lightweight input shafts for quicker acceleration and throttle response.
* Integrated spur gear mount adds rigidity and prevents spur gear flex.
All this and more data can be yours at the HPI website at http://www.hpiracing.com/index2.htm
Ira
Has anyone tried the HPI bearing adapters that let you switch to 5x8x2.5 bearings for the axles (i.e., the bearings go in the steering blocks (front) and hubs (rear)). I just got a set and am about to try them, but wanted to hear if there were any nasty surprises awaiting me.
Ira
Ira
any good carpet set ups going to snowbirds
any body got any good carpet set ups going to birds
I have been snapping diff screws in mod. Rigth at the head. Any one find one that holds up?
I was having that problem in stock. Apparently the AE TC3 ones work but I was snapping them too. The only response I was given was "Don't crash!!"
Good luck.
Ira
