NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 01-21-2013, 08:28 AM
  #10456
Originally Posted by chris_dono
There's two ways
1: Plug the speedo into a computer and use the PC Software to change modes (on the first tab when you connect the speedo)
2: Using a 2-in-1 programming box, connect the speedo and switch it on. Once it's gone to the first item, press the R/P button. This will show you which mode you are in. From there, press the value button to change between stored modes. Don't forget to press ok
I have done this with the box and select blinky mode then ok seems to still have all of the timming and boost available not sure if when i hit ok to mode 2 it does anything
Huskerfan1212 is offline
Old 01-21-2013, 08:41 AM
  #10457
if you've changed the settings on mode 2 at all, then simply set the boost and turbo values to 0. Now you're in blinky mode.
Any mode with boost and turbo set to 0 will be blinky, but on official lists (Roar, BRCA etc) it specifies you must be in mode 2
chris_dono is offline
Old 01-21-2013, 09:38 AM
  #10458
Trader Rating: 88 (100%+)
Subscribed.
MUDVAYNE is offline
Old 01-21-2013, 09:42 AM
  #10459
Hey guys,
I have been noticing a strange power fading at 3/4 of the straightway. Motor comes off at 120F after 3-4 mins of hard racing. Here is some of the info from the top off my head:
ESC: Hobbywing V3 120A
Motor: Trinity D3 10.5 (0 deg line)
Boost: 38
Turbo: 25
Pinion: 33T
Spur: 112T
FDR: 6.45
I'll try to post the full setup when I get home.
Thanks.
Serpenteer is offline
Old 01-21-2013, 10:10 AM
  #10460
Originally Posted by sosidge
Punch at 1 is very low. I've never run below 7 myself. I have a feeling that someone, somewhere mentioned that the ESC needs to be at quite a high punch level for the timing to actually engage (never tested myself).
That's interesting I'll try that.
UberPare is offline
Old 01-21-2013, 10:19 AM
  #10461
Originally Posted by Serpenteer
Hey guys,
Motor: Trinity D3 (0 deg line)
Boost: 38
Turbo: 25
Pinion: 33T
Spur: 112T
FDR: 6.45
Thanks.
Which wind of motor ? and we'll need full settings to be honest....
Old 01-21-2013, 11:34 AM
  #10462
10.5
Here is the full setup:
Motor: Trinity 10.5 D3 (Endbell zero)
General
1A: FWD/BRAKE
1B: 25%
1C: Auto
1D: 105*C
1E: 105*C
Throttle
2A: 50%
2B: 30
2C: 30
2D Linear
Brake
3A: 0
3B: 100
3C: 0
3D: 50
3E: 20
3F: 20
3G: Linear
Boost:
4A: 39
4B: 3000 RPM
4C: 16000 RPM
4D: Linear
4E: No
Timing:
5A: 25
5B: Full Throttle
5C: 0.1s
5D: 15,000
5E: 18 deg/.1 sec
5F: 24 deg/.1 sec
Old 01-21-2013, 12:05 PM
  #10463
10.5
General
1A: FWD/BRAKE
1B: 25%
1C: Auto
1D: 105*C
1E: 105*C
Throttle
2A: 50%
2B: 30
2C: 30
2D Linear
Brake
3A: 0
3B: 100
3C: 0
3D: 50
3E: 20
3F: 20
3G: Linear
Boost:
4A: 39
4B: 3000 RPM
4C: 16000 RPM
4D: Linear
4E: No
Timing:
5A: 25
5B: Full Throttle
5C: 0.1s
5D: 15,000
5E: 18 deg/.1 sec
5F: 24 deg/.1 sec
Start RPM's for boost is too low, bring it up to around 7,000 (end at 23 ,000ish, and bring the turbo in at 23,000 as well)
Old 01-21-2013, 03:46 PM
  #10464
What settings can i adjust but still be in blinky
Old 01-21-2013, 06:41 PM
  #10465
Originally Posted by idbdoug
i have Xerun 120A 1S model. What is correct voltage cutoff for 1cell lipo's????? Will be used in 13.5 WGT
idbdoug
3.0v
trackdog is offline
Old 01-21-2013, 07:05 PM
  #10466
idbdoug's Avatar
Trader Rating: 41 (100%+)
Originally Posted by trackdog
3.0v
idbdoug
idbdoug is offline
Old 01-21-2013, 11:04 PM
  #10467
Trader Rating: 16 (100%+)
idbdoug
I suggest that you contact CRC (the US distributor) for the correct voltage cutoff setting.
Bill
Still Bill is offline
Old 01-22-2013, 01:48 AM
  #10468
cyanyde's Avatar
Agree with your advise. But there is something definitely wrong. With his setup the car should be ripping already and with a hot motor. Losing breath on the straight with a cold motor tells me its running mild boost but it isn't. Either there is an issue with the sensors, sensor wires or something else..
Try swapping sensor wires first then motor.
cyanyde is offline
Old 01-22-2013, 10:30 AM
  #10469
I'll try swapping the wires then motor, thanks for your advice!
Reason why I disregarded wires and motor is a friend of mine was running the exact same combo (10.5 D3 / HW V3) with similar boost/timing setting and FDR and was experiencing the same problem. It is almost as if the motor goes blank then recovers for when you brake/release throttle. I wouldn't disregard my motor being bad since it has already a full season on it. But my friend's motor was new.
Any other advice is welcome since I don't want to be clueless on the next race and have to switch to a V2 HW if I cannot figure out what is wrong.
Old 01-22-2013, 10:48 AM
  #10470
aSab's Avatar
it could also be the battery if it were only your problem. then I'd suggest to try a fresh, out-of-the-box battery. my 3yr old batteries can't feed enough juice to my Xerun, I've experienced that already. but since your buddy has the same problem...who knows, maybe his battery is also out of shape?
aSab is offline
