Like Tree220Likes
Tamiya FF03
Old 06-10-2010, 09:30 AM
  #346
kentech's Avatar
Tamiya Japan product page
http://www.tamiya.com/japan/products...3pro/index.htm
kentech is offline
Old 06-10-2010, 02:12 PM
  #347
Trader Rating: 28 (100%+)
madjack is offline
Old 06-11-2010, 01:30 AM
  #348
kentech's Avatar
More @ http://kentech.blogs.se/
kentech is offline
Old 06-11-2010, 02:29 AM
  #349
Originally Posted by kentech
Thanks for the pics. answered my question on gearing. Did you find out the max size pinion with the cover on? Also, how heavy is the car at ready to run state?
inpuressa is offline
Old 06-11-2010, 03:05 AM
  #350
kentech's Avatar
Don't know on the pinion and cover. 40 is at least ok.
Without body with the electronics I have: 1235g
With heavy Golf body: 1375g
Weight is very far forward.
kentech is offline
Old 06-11-2010, 08:18 AM
  #351
OSherman's Avatar
Thumbs up
looks like a fairly simple build... nice!!
OSherman is offline
Old 06-11-2010, 09:39 AM
  #352
OSherman's Avatar
Kentech... does kit come with full bearings? (noticed you had to place bearings in steering rack)
also, regular toe blocks in rear?
OSherman is offline
Old 06-11-2010, 09:55 AM
  #353
Hebiki's Avatar
Trader Rating: 26 (100%+)
i think its typical tamiya.. bearings through out.. but the steering rack has no bearings only bushings.
Hebiki is offline
Old 06-11-2010, 12:15 PM
  #354
kentech's Avatar
Full bearings yeah, just bushings in the steering and the rockers as you would expect.
Plastic toe blocks in the rear, XD and A.
X and B also included. Alu blocks will fit.
kentech is offline
Old 06-11-2010, 01:15 PM
  #355
rtypec's Avatar
Default Mr Tanaka say "Sweat from beaneath monkey ballr make you beeeery faaaast!"
I've got a quick question. Has anybody confirmed which rear carbon shock tower will work with the FF03? I'm scrounging part numbers up for an order in anticipation for a build (minus a bunch of "out of stock/on the boat" hopups) and would like to add the rear damper stay. Thanks in advance!
rtypec is offline
Old 06-11-2010, 03:53 PM
  #356
tamiyarcracer's Avatar
Rod,
None will work right, the plastic tower has the rear shock locations laid over much further than the TB03 or the TA05 towers. Not to mention, the towers will need modification to fit on the bulkhead. But the bolt pattern is he same as both the TA05 and TB03 if you want to modify them, and see if the locations might work.
The rear shocks are laid over like the front shocks on the M05.
tamiyarcracer is offline
Old 06-11-2010, 03:58 PM
  #357
Orlando,
PM me your email, I will send you the manual when I settle in tonight in Fremont
Old 06-11-2010, 04:32 PM
  #358
OSherman's Avatar
Originally Posted by tamiyarcracer
Orlando,
YGPM.
thanks
OSherman is offline
Old 06-11-2010, 06:46 PM
  #359
akura2's Avatar
Just got my Beams Integra Body... it's going on my FF01 in the meantime until I decide to ask my wife for some money to go buy a FF03....
Still saving for a Thunder Tiger SB5 and a Venom VMX450 though so we'll see
akura2 is offline
Old 06-11-2010, 09:24 PM
  #360
For those who look for an editable setup sheet, you can find one here.
Raw materials is from kentech, I just made it editable and that can be considered as temporary until Tamiya releases the official one.
HTH
Arn0 is offline
