Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 12-18-2008, 05:47 AM
  #14776
dizzy1's Avatar
Trader Rating: 29 (100%+)
I've been using the cheap 3racing knuckles found off ebay for over a year, still haven't bent them or tweaked them. I haven't seen any other parts break from this, so it didn't seem to pass the damage to the uprights or arms. I also don't crash much, so if you track is nasty or your a real door banger, you might want to up for the better quality HPI knuckles from Japan. I also didn't notice any drop in front end grip, so there is still enough flex up front so that's not a real issue.
To be honest, I'm surprised HPI/Hot Bodies hasn't fixed this problem years ago. Coming from a Pro4, the issue started right when they introduced the knuckles with the little bubble so the steering would turn as far. Ever since then it splits knuckles down the front mold seem. I talked to Jeremy when he first started at HPI and sent him some examples, they were supposed to take a look at this to see if its and issue. Guess HPI figured they needed to keep selling knuckles!
dizzy1 is offline
Old 12-18-2008, 10:41 AM
  #14777
edseb's Avatar
Originally Posted by STLNLST
UPS delivered my package this evening so I weighed the packs. The 3800 is 8.0oz or 228g I know that you have some coming but hopefully this will aloow you to get a jump on your balancing system.
Cool, I guess the weight is the same.
edseb is offline
Old 12-18-2008, 12:17 PM
  #14778
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
I just got my motors and batteries today so I haven't had a chance to run them yet. The speedo has to wait until the first of the year for two reasons.
1. Christmas has me a little tapped out.
2. I want to run the motor using the LRP so that I get a feel for how the motor runs.
I think that after one day of racing I will have a good feel for how these motors run and after that I can then switch to the Orion speedo.
Ahhh, ok.
Im building a B4 for my buddy. Will probably run a orion 13.5 I have a 5,6, and 7.5 already These motors are really efficient it seems like. Great run time (even with a 5.5) and cool running. But I will let the motor man decide on there 13.5 LOL.
I think I will just back order a orion speedo. And get it next year
BlackedOutREVO is offline
Old 12-18-2008, 12:33 PM
  #14779
edseb's Avatar
Sorry you are having so many issues with your knuckles. I'm still running the kit ones and haven't broke any yet. Maybe its the track you run on cause the guys running the cars out here haven't really voiced that problem and there are a lot of TCs out here. Not to say some of the guys haven't broke that part, but it doesn't look unusual compared to what normally breaks in a crash. Might just be a bad string of luck. If you are talking about Jeremy Felles, he no longer works for HB, so it may have been overlooked. Just a guess.
edseb is offline
Old 12-18-2008, 12:59 PM
  #14780
STLNLST's Avatar
Trader Rating: 32 (100%+)
I haven't really broken knuckles until just recently. I like having a back stock but you can't really do that with HB parts since they don't come in pairs. If I don't get the alum one's from TOP I guess I'll go with the regular parts and give the rear hubs to a novice racer.
STLNLST is offline
Old 12-18-2008, 01:16 PM
  #14781
Hi Dizzy1,
Sorry to hear the parts breakage that happening to your car.
As for the knuckle, we have checked all the stock parts and tested with them in the past but they all were ok. Also, there is no difference between the knuckles from Japan and from the US. They all are completely the same knuckles.
I believe that it all depends on what type of the race tracks you run on. Since they are not aluminum knucles, they still break in some cases (i.e: hard impact, etc). However, they are not so weak and have decent durability.
We really appreciate your input though.
Please feel free to let us know whenever you have a questions or concerns.
you can always reach me at [email protected]
Regards,
Hiroyuki Kasuya
Hi-LowBlow is offline
Old 12-18-2008, 01:38 PM
  #14782
shadow102's Avatar
Trader Rating: 21 (96%+)
I agree...no matter what crash I am in the rear hub holds up. I have a huge pile of them. This would all be solved by packaging the knuckles different.
I think I broke my knuckle the worse the other day. Nobody could believe it but I split it along the seam where the bearings sit, broke the steering arm off and broke my c-hub in two. Oddly enough this is on a track that so far has seemed very very easy on cars
shadow102 is offline
Old 12-18-2008, 02:00 PM
  #14783
artwork's Avatar
Trader Rating: 88 (100%+)
Has anyone built a roll center calculator like some people have built for some other cars? I was recently looking at the one in the Tamiya forums and found it very useful.
artwork is offline
Old 12-18-2008, 02:42 PM
  #14784
i too have had the problem with the steering hubs..they do break right along the seam...i have a 3 racing aluminum set on the way...have only raced this car 4 times..and not hit hard..but broken 2 steering hubs...have hit things much harder with tc5 and not broken...
i am cornholio is offline
Old 12-18-2008, 05:02 PM
  #14785
STLNLST's Avatar
STLNLST is offline
Old 12-18-2008, 06:06 PM
  #14786
I ran my cyclone for the first time tonight, WOW what a difference form a TC3 I was running the one way but sounded like nothing I have never heard before. In the corners with on power i was hearing something but the drive terain was free, it sounded like it was the tires gripping hard. I can't really describe the sound. The car handeled great though
Tulsa TC3 is offline
Old 12-18-2008, 06:36 PM
  #14787
Trader Rating: 74 (100%+)
Probably chatter from the axles,too much steering throw
steve eaves is offline
Old 12-18-2008, 06:53 PM
  #14788
thanks
Old 12-18-2008, 07:00 PM
  #14789
what is the difference between running the carbon fiber rear brace vs. the stock purple (heatsink)
Old 12-18-2008, 07:26 PM
  #14790
shadow102's Avatar
the CF brace will give more rear traction due to extra chassis flex. If your running rubber tire i suggest the CF brace.
