Like Tree4Likes
Tamiya TRF417
Old 07-12-2013, 06:18 PM
  #5626
OnRDPassion's Avatar
Trader Rating: 59 (100%+)
Originally Posted by Csaari77
I'm in the middle of a rebuild and I'm trying to figure out the best place to mount my new Mylaps transponder. Until now I've only had the older PT and just mounted it on top of the servo. Does anyone actually use the mount that comes in the kit? I thought about using it but I wasn't very happy with how far out the transponder sits off the servo.
I ended up mounting mine right on top of the receiver, no issues what soever and gets it really close to the chassis. If you want to see what I'm talking about I can post a picture.
OnRDPassion is offline
Old 07-12-2013, 06:57 PM
  #5627
Csaari77's Avatar
Trader Rating: 35 (100%+)
The reason I considered using the mount was to ensure that I could remove the transponder quickly and easily. I've always just used velcro to attach it to the servo. I tried to attached one to the bumper brace once on an Evo IV and the wires got severed in a nasty crash.
Csaari77 is offline
  #5628
Typeone's Avatar
Trader Rating: 50 (100%+)
Question should I put the urethane bushings in the work shocks or should it be fine running without them?
Typeone is online now
Old 07-12-2013, 08:33 PM
  #5629
narcotiks's Avatar
You generally don't run the foam insert at all.
narcotiks is offline
Old 07-12-2013, 09:26 PM
  #5630
Typeone's Avatar
Ok thanks
Old 07-12-2013, 09:32 PM
  #5631
What are the main difference between the 417, 417x and 417v5?
missouri racer is offline
Old 07-12-2013, 11:24 PM
  #5632
racer x 1's Avatar
Trader Rating: 27 (100%+)
ok so im pretty to my 417x and had a question about tamiyas spring offerings.
what is the difference performance wise between the white long type and black short type springs? is there a real difference on the track.
Oh and after two packs I literally feel in love with on road again! I have not driven any sedan that was this good from the get go!
racer x 1 is offline
Old 07-13-2013, 08:00 AM
  #5633
JoeyE's Avatar
Trader Rating: 45 (100%+)
I also mounted mine on the Rx with no issues.
JoeyE is offline
Old 07-13-2013, 02:34 PM
  #5634
NItrox416's Avatar
You can also put the trasponder in front of the battery.
A question for all. How much do your cars weight? I'm struggling to keep mine under 1400g considering that in my championship the limit is 1350
Any suggestions?
PS
I already have low profile servo, lw body, light esc(sxx) and motor (x12), short wires , battery 320g.
NItrox416 is offline
Old 07-13-2013, 03:59 PM
  #5635
JoeyE's Avatar
Any suggestions?
PS
Mine is 1340. I have to add weights to mine.
JoeyE is offline
Old 07-13-2013, 05:15 PM
  #5636
Potoczak's Avatar
Trader Rating: 120 (100%+)
Nib v5 for sale. Pm for details
Potoczak is offline
Old 07-13-2013, 07:07 PM
  #5637
nolo148's Avatar
Any suggestions?
PS
Mine is 1380 with a 50c(300g) battery and 1390 with a 65c battery(310g). The weight limit is 1380g. Mine used to be like 1450 but I removed the battery stops which were like 15g ea, moved to a low profile servo (saved almost 20g) and I switched to a lw body. Right now the heavier parts are probably steel cups on the spool, dcj all around, mostly steel screws that are like 1-2mm above the hole for the alluminum parts, steel turnbuckles for steering, and messy receiver wiring and a big capacitor.
I'd suggest a lighter battery. check out the battery vs weight thread, it's pretty interesting.
nolo148 is offline
Old 07-14-2013, 08:38 AM
  #5638
Default Setup for Tamiya Type-A tires
Hi guys, I am really struggling to get steering out of my 417X for our Tamiya Cup race this weekend coming. We have to run either A or B compound tamiya tires and only Tamiya parts as you all know. My car just seem to grain the front tires,but I have to really back off the throttle to get the car to turn on power and off power. Does anybody have a setup for these crappy tires. We run the Tamiya 18T system and gear them 51T/90T. The track is tight and narrow with banked and off camber turns. Will a tire additive help? I am so frustrated.
NovakSA is offline
Old 07-14-2013, 08:48 AM
  #5639
narcotiks's Avatar
Can you post your current setup on a setup sheet? that will make it easier for everyone to point you in the right direction
Old 07-14-2013, 08:53 AM
  #5640
NItrox416's Avatar
Thanks for help, I've all the screw of the original kit
If I change the the screw set with a lighter how many grams
I would save?
Which is a good method to shorten wires? I've tried some time ago but I
was unable to place the connector, so I ended up soldering directly a new short wire on the servo. Any suggestion?
