Like Tree1Likes
Xray T4'14
Old 01-06-2014, 02:26 AM
  #991
daleburr's Avatar
Originally Posted by Krafcik
Why would it strip? We run outdoor like this and don't have arms stripping.
On TC you tend to take the shocks off more regularly than off-road. You'll remove them to change diff oil, change springs, change shock oil, rebuild the shocks, set the droop, check for free suspension movement, clean them etc etc.
On my buggy I rarely remove the shocks so screwing into the arm works alright (although still not as nice as the Xray mounts).
daleburr is offline
Old 01-06-2014, 07:56 AM
  #992
Moderator
Clegg's Avatar
Why would you be going out of your way to not use the shock mounting system that is stock? Works great. Yes you can do it other ways, but why would you want to when there is a greater risk of damaging the arm?
Clegg is offline
Old 01-06-2014, 07:59 AM
  #993
Jon Williams's Avatar
Originally Posted by daleburr
If you use a screw straight into the arm, sooner or later the arm will strip from regular removal of the shock.
The xray system is fantastic and like it for a reason.
^^^This. Makes no sense to do otherwise.
Jon Williams is offline
Old 01-06-2014, 05:25 PM
  #994
Trader Rating: 38 (100%+)
What's the best method for holding a lipo in place? I've seen the Xray graphite strap set, but it's $45. I've seen a velcro strap on Ebay for around $20. Is the graphite worth the extra $20 splurge?
Breakin2 is offline
Old 01-06-2014, 05:34 PM
  #995
rangerjkb's Avatar
Trader Rating: 45 (100%+)
Several good methods exsist, I prefer using the Xray graphite adjustable battery holders with the RSD battery hold down posts/tabs.
rangerjkb is offline
Old 01-06-2014, 05:48 PM
  #996
erchn's Avatar
^^^ +1
XRA306188
and
http://www.reflexracing.net/RSD-Batt...AY_p_1343.html
This looks like a nice option too, but I've not tried it.
http://www.reflexracing.net/RSD-XRAY...op_p_2149.html
erchn is offline
Old 01-06-2014, 06:03 PM
  #997
Very cool. Thanks!
Breakin2 is offline
Old 01-06-2014, 06:05 PM
  #998
Trader Rating: 70 (100%+)
Can't beat the reflex hold downs imo. I put a small piece of carpet tape in the middle of my pack and it doesn't move but still allows the chassis to fully flex.
PROMODVETTE is offline
Old 01-06-2014, 07:49 PM
  #999
Osiris 75's Avatar
Trader Rating: 18 (100%+)
Osiris 75 is offline
Old 01-06-2014, 07:56 PM
  #1000
Try puretech straps amain has them for 8 bucks you get 2 works good for me lots of colors too
Justin33 is offline
Old 01-06-2014, 08:16 PM
  #1001
Trader Rating: 27 (100%+)
+1 for the graphite battery holders + RSD hold down
If not, a bunch of guys are using just tape, nothing else.
hyujmn is offline
Old 01-06-2014, 08:51 PM
  #1002
Just tape for me, I"ve done other options and this one is the best for me.
Mclarein is offline
Old 01-06-2014, 09:13 PM
  #1003
Odin544's Avatar
Trader Rating: 93 (100%+)
Just tape for me. I don't see any of the top drivers using anything different either.
Odin544 is offline
Old 01-07-2014, 04:27 AM
  #1004
marvcat1's Avatar
Default RSD battery holder
RSD is the best holder I agree. Plus continues with the OEM look of the chassis.
marvcat1 is offline
Old 01-07-2014, 07:53 AM
  #1005
Trader Rating: 13 (100%+)
+1 for tape.
I had the RSD holders on my '13, and ended up just selling them with the car.
Sean B. is offline
