Team Associated T5M Discussion
#752
I spent yesterday evening and this afternoon cleaning my T5M up and getting it ready for this weekend's Northwest Indoor Series race at Tacoma RC Raceway. Today I was able to piece together a Lunsford turnbuckle kit from my LHS and my parts order arrived from Tower. Now I just have to wait patiently for my new motor to get here and it will be ready to go.
#753
The build was every bit as good as my B5M. No missing parts, instructions were easy. Kit setup is a touch soft in the rear and needs more steering, but it is very easy to drive. I wasn't sure about using the kit slipper with a mod motor, so I used a VTS setup out of my spares bin. I like that it drives just like my X-60CF - so much so that the kit setup is identical except for rear shock oil/piston to my current setup on the X Factory. If you are running indoor with decent grip I would recommend going to a 1.6mm 2 hole piston with 30wt oil in the rear shocks. I would also recommend double checking that you use Loctite on the front axle retaining screw. I forgot on mine and it made it about 2 minutes before the LF wheel and axle assembly fell out. Also, T4 turnbuckles will not work with this kit. I tried, and while they will work for the steering and front camber links, you won't have enough adjustment in the rear if you run a setup with a shorter link.
Pros:
Aluminum ball stud mount
Lightweight top shaft
Fantastic build quality
Instructions are easy to follow
Kit setup is very drivable
Ball cups are free without any extra work
New style shock oil bottle is very good (same style as TLR)
Cons:
Steel turnbuckles (good for 1 run in stadium truck - buy Lunsford and build it with them)
Non-vented V2 slipper
No wheels in the kit (not a real big deal, but may be a surprise for some)
Not enough shims included in the kit to properly position the rear arms
Overall I would say the ball stud mount and lightened top shaft is a fair trade for not including wheels, and the quality of the plastics is infinitely better than the B4/T4 - though I think many will be a little bit disappointed at the omission of the VTS and titanium turnbuckles. I have not driven the truck in 17.5 trim (shorty pack/slipper eliminator), but with a square pack and an 8.5 it was easy to get around the track. A solid 7.5/10 to be sure.
Pros:
Cons:
#754
#760
With the new truck going to the 3 gear do you have to get the different top shaft like you did with the buggy? Or is all you need the case and motor plate?
#764
This may be a dumb question as I haven't really read every page here.. Did a simple google search and it didn't return anything useful.
Are they going to make a RM version or is this supposed to be fine on all track conditions. From what I was told at my LHS, MM sucks on our track, so this truck won't work for me ( I think).. Assuming MM trucks drive similar to the MM buggies.
I have a T4 now that I have been slowly updating, sans the BB shocks and VTS slipper. My plan was to just get the T5 when it came out, but if they aren't going to release a RM version, I'll just get the shocks and call it a day.
#765
