HPI R40 Nitro Car Forum
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
Originally Posted by CraigM
Hey Harry, your car looks to have all the hop ups, are there any that you would recommend?
What car do you have?..
Does anybody else have problems with the lightweight 2spd getting stuck on 2nd gear? I was at the track last weakend and had that problem. I ended up grinding the shoes so they would close a little more. Although Im still not sure if its shifting.
instead of gring the shoes so they are closer together,LIGHTLY sand the outside edges of the shoes.....
hara car
the 2 speed had the wrong screw in the kit. 2.6mmx12 -silver screw ok the black screw had a phillips head and the top was to big . tower is out of the screw. why would hpi put the car out with out extra screw ,if this screw is soo hard to find.
Originally Posted by fastharry
the green slime that associated sells for shock building is a lubricant that will have no viscous action in the diffs......you only want to use some type of heavy weight grease designed for diffs ot silicone....I run a 4 gear diff and 30,000 weight oil(though that combo maight be a little to hard to handle on some unclean parking lot surfaces)...
I had some problems with my 2 speed getting stuck in top gear but found that the grub screws weren't set right. I found the instructions weren't very helpful for the 2 speed so just found my own settings through trial and error.
Harry I've got a 2005 r40 but at the moment it's stock apart from the clutch and springs
you have a hara edition?..
I did that and always got a good shift.
yes its the hara car!
Non hara edition
Non hara edition
The 2005 has that already...
"2005 Version Comes with these Extras:
#73089/73090 Graphite Shock Tower
#87172 Lightweight 2-speed Transmission
#73925 Hara Edition Chassis
#73110 Hara Edition Upper Deck
#87241 Hara Edition Fuel Tank
#75067 Aluminum Servo Mount
#33407 Clamp Type Hex Hub
#33403 R40 Steering Upgrade
#33401/33402 2-Sp Shaft, Middle Shaft"
Well it's sold as the 2005 edition, but yes looking on the HPI site it looks to have all the same upgrades
Yes you are right. The Asian version is called the "Hara". The US verison is called "2005". They are both the same. There was also a 04 "Hara" version available only overseas. There was a lot of confusion here when the 05/Hara kit was released. Seems like everybody just calls it the "Hara" editon now.
