Old 03-25-2007, 06:00 AM   #11266
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Originally Posted by CraigM
Hey Harry, your car looks to have all the hop ups, are there any that you would recommend?
What car do you have?..
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 03-25-2007, 09:33 AM   #11267
nitrodude's Avatar
Does anybody else have problems with the lightweight 2spd getting stuck on 2nd gear? I was at the track last weakend and had that problem. I ended up grinding the shoes so they would close a little more. Although Im still not sure if its shifting.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 03-25-2007, 11:11 AM   #11268
fastharry™'s Avatar
instead of gring the shoes so they are closer together,LIGHTLY sand the outside edges of the shoes.....
Old 03-25-2007, 01:32 PM   #11269
Default hara car
the 2 speed had the wrong screw in the kit. 2.6mmx12 -silver screw ok the black screw had a phillips head and the top was to big . tower is out of the screw. why would hpi put the car out with out extra screw ,if this screw is soo hard to find.
LORD SHADO is offline   Reply With Quote
Old 03-25-2007, 01:41 PM   #11270
Originally Posted by fastharry
the green slime that associated sells for shock building is a lubricant that will have no viscous action in the diffs......you only want to use some type of heavy weight grease designed for diffs ot silicone....I run a 4 gear diff and 30,000 weight oil(though that combo maight be a little to hard to handle on some unclean parking lot surfaces)...
i used it in my 7.5 kyosha diff work perfectly no problems.
Old 03-25-2007, 07:17 PM   #11271
CraigM's Avatar
Trader Rating: 34 (100%+)
I had some problems with my 2 speed getting stuck in top gear but found that the grub screws weren't set right. I found the instructions weren't very helpful for the 2 speed so just found my own settings through trial and error.
Harry I've got a 2005 r40 but at the moment it's stock apart from the clutch and springs
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 03-25-2007, 07:38 PM   #11272
fastharry™'s Avatar
you have a hara edition?..
Old 03-25-2007, 07:38 PM   #11273
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Set the 2 speed shoes so there is just a slight crack. Then make sure the adjustment screws are almost able to be touched. Just slightly in.
I did that and always got a good shift.
Artificial-I is offline   Reply With Quote
Old 03-25-2007, 08:23 PM   #11274
yes its the hara car!
Old 03-25-2007, 08:24 PM   #11275
CraigM's Avatar
Non hara edition
Old 03-25-2007, 08:31 PM   #11276
fastharry™'s Avatar
Non hara edition
well,the best option is the LW 2 speed....
Old 03-25-2007, 09:01 PM   #11277
CraigM's Avatar
The 2005 has that already...
"2005 Version Comes with these Extras:
#73089/73090 Graphite Shock Tower
#87172 Lightweight 2-speed Transmission
#73925 Hara Edition Chassis
#73110 Hara Edition Upper Deck
#87241 Hara Edition Fuel Tank
#75067 Aluminum Servo Mount
#33407 Clamp Type Hex Hub
#33403 R40 Steering Upgrade
#33401/33402 2-Sp Shaft, Middle Shaft"
Old 03-25-2007, 09:10 PM   #11278
Rapid Roy's Avatar
Dude, that is the "Hara" edition
Rapid Roy is offline   Reply With Quote
Old 03-25-2007, 09:46 PM   #11279
CraigM's Avatar
Well it's sold as the 2005 edition, but yes looking on the HPI site it looks to have all the same upgrades
Old 03-25-2007, 10:07 PM   #11280
Rapid Roy's Avatar
Yes you are right. The Asian version is called the "Hara". The US verison is called "2005". They are both the same. There was also a 04 "Hara" version available only overseas. There was a lot of confusion here when the 05/Hara kit was released. Seems like everybody just calls it the "Hara" editon now.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
