Like Tree485Likes
Yokomo YZ-2
    Hide Wikipost
Old 11-11-2021, 01:35 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-2
Last edit by: lexusbest
Welcome to the YZ2 Wiki!
Features for the lastest specification YZ-2DTM3.1
  • Long specification for dirt Main chassis Inheriting the chassis cut of dirt specification, it is longer with the same wheelbase as CAL3.
  • Aluminum front suspension mount.
  • Z2-DTM2B F2 body.
  • JConcepts ASTRO High Clearance 7inch Wing.
Features for the lastest specification YZ-2CAL3.1
  • Long specification main chassis for carpets. Long wheelbase that enables even higher speeds.
  • Steel front suspension mount.
  • Z2-DTMBL S2 Lightweight body.
  • Z2-CAL2W LMR Wing.
Common features for the lastest specification YZ-2DTM3.1 / YZ-2CAL3.1
  • The conventional position and the position of the suspension arm pin 1 mm higher can be selected on the front and back of the front suspension mount.
  • Bulkhead integrated side plate with increased rigidity.
  • The kingpin position has been changed with the new steering hub carrier, the axle position has been lengthened by 1 mm, and a steering stopper has also been added.
  • Battery holder that is easy to adjust according to the height of the battery.
  • Separate the rear mount base and upper arm holder to increase the flex around the rear and improve traction.
  • Z2-018-5 5-hole shock mounting specification Rear shock tower.
  • S4-S1S 3.0mm shaft specification front shock.
  • S4-S1M 3.0mm shaft specification rear short shock.
  • S4-008R5B L5 / LD Rear suspension arm (Φ3.5 pin).
  • Z2-01069 Rear universal shaft (69mm bone).
Setup Sheets can be found here
DT CA DTM parts comparison
YZ2T Tranny Conversion List
YOKZ2-300RFT
YOKZ2-302CT
YOKZ2-302T
YOKZ2-304T
YOKZ2-503I
YOKZ2-0023
CAL3 manual
DTM3 manual
Print Wikipost
Old 08-31-2016, 05:00 PM
  #2416
Team Tekin
Randy_Pike's Avatar
Doubtful. The current Ca/Dt car is pretty dialed. Get the DT and then pick up the CA 3 gear and you'll have both. Swapping is easy and only takes a few minutes.
Tires are only going to get better, making the laydown a bit more practical.
Randy_Pike is offline
Old 08-31-2016, 05:10 PM
  #2417
veecee's Avatar
Trader Rating: 34 (100%+)
Thanks Randy
veecee is offline
Old 08-31-2016, 07:20 PM
  #2418
Default Are Extra bits required for laydown trans??
Hi Randy ,
Does the CA laydown work with the DT shock tower and upper arm mount or do you need to buy the CA ones??
sm77 is offline
Old 09-01-2016, 01:47 PM
  #2419
JAE
Trader Rating: 30 (100%+)
What parts would you order to have on hand in case of breaks? Have zero track support
JAE is offline
Old 09-01-2016, 02:29 PM
  #2420
Paultje040's Avatar
Hi Randy ,
You need the CA Gearbox, motormount, idlergear, shocktower, batterystrap, and upper arm mount.
Paultje040 is offline
Old 09-01-2016, 02:31 PM
  #2421
Paultje040's Avatar
I have broken 1 ballcup and 1 rear arm (head-on crash) on my YZ2, and have been racing it sinds the day it came on the market.
So set of arms and ballcups i guess
Old 09-01-2016, 03:06 PM
  #2422
MarkA's Avatar
Trader Rating: 21 (100%+)
The front bulkhead is, along with rear arms, the only thing I've broken more than one of.
MarkA is offline
Old 09-01-2016, 11:10 PM
  #2423
Arms and front bulkhead.
matterooth is offline
Old 09-02-2016, 02:02 PM
  #2424
Ty
Ty's Avatar
Trader Rating: 32 (100%+)
I am ordering a YZ-2 DT today. Can someone please post the part numbers to use the "Carpet" laydown tranny? I already have the transmission case set in my cart (YOKZ2-302C3) but I was wondering if anything else is needed. Thanks so much and looking forward to racing this buggy.
Ty is offline
Old 09-02-2016, 02:49 PM
  #2425
Paultje040's Avatar
4 posts up
Old 09-03-2016, 01:29 PM
  #2426
JAE
What's the "upper arm mount"? This the front shock tower and is it 100 percent necessary? Pm me if anyone has a 3 gear laydown for sale thx
JAE is offline
Old 09-03-2016, 05:12 PM
  #2427
JAE
You mind listing the part numbers that you used for the laydown conversion you bought? May be in the same boat...
JAE is offline
Old 09-05-2016, 08:10 PM
  #2428
So I'm considering getting back into 2wd Buggy (I've been away from racing for a few years). There's a new indoor track where I live that is described as med-high traction clay/dirt. I've been looking through this thread and found lots of good info but it's still not clear to me how many (if any) additional extras are required to make a YZ-2 DT competitive. It seems like with many of the other buggies there is a lot of additions/hop-ups/kluges required to make them their best. Is the YZ-2 DT any different or could I expect it to be good right out of the box? Thanks in advance for any insight you can provide.
Cheers!
Hyper_Mike is offline
Old 09-05-2016, 08:34 PM
  #2429
Trader Rating: 79 (99%+)
Hyper mike check your pm!
Raul Garcia is offline
Old 09-06-2016, 12:25 AM
  #2430
ProfessorX's Avatar
Trader Rating: 18 (100%+)
Here comes a sales pitch.
ProfessorX is offline
