Yokomo YZ-2
#2416
Doubtful. The current Ca/Dt car is pretty dialed. Get the DT and then pick up the CA 3 gear and you'll have both. Swapping is easy and only takes a few minutes.
Tires are only going to get better, making the laydown a bit more practical.
#2417
#2418
Are Extra bits required for laydown trans??
Hi Randy ,
Does the CA laydown work with the DT shock tower and upper arm mount or do you need to buy the CA ones??
Hi Randy ,
#2419
What parts would you order to have on hand in case of breaks? Have zero track support
#2420
Hi Randy ,
Hi Randy ,
#2421
#2423
Arms and front bulkhead.
#2424
I am ordering a YZ-2 DT today. Can someone please post the part numbers to use the "Carpet" laydown tranny? I already have the transmission case set in my cart (YOKZ2-302C3) but I was wondering if anything else is needed. Thanks so much and looking forward to racing this buggy.
#2425
#2426
#2427
You mind listing the part numbers that you used for the laydown conversion you bought? May be in the same boat...
#2428
So I'm considering getting back into 2wd Buggy (I've been away from racing for a few years). There's a new indoor track where I live that is described as med-high traction clay/dirt. I've been looking through this thread and found lots of good info but it's still not clear to me how many (if any) additional extras are required to make a YZ-2 DT competitive. It seems like with many of the other buggies there is a lot of additions/hop-ups/kluges required to make them their best. Is the YZ-2 DT any different or could I expect it to be good right out of the box? Thanks in advance for any insight you can provide.
Cheers!
Cheers!
#2430
