Hot Bodies D413 1/10 4WD Buggy >
Like Tree66Likes
Old 09-08-2014, 07:28 PM
  #4531
JasonR/C's Avatar
With a 6.5 I have tried a 22-23 pin and had higher temps. Went to a 25pin and the temps dropped and man was my car fast. Outdoor medium traction. With a 6.5 I do thinks the 22 range is alittle under geared
JasonR/C is offline
Old 09-08-2014, 09:26 PM
  #4532
Trader Rating: 17 (100%+)
Hmm that is interesting. What were the temp differences and what diff setup!
AlderBoy is offline
Old 09-09-2014, 04:00 AM
  #4533
Hello. Tell me please, differential gears in this model sintered or machined?
foobar is offline
Old 09-09-2014, 05:39 AM
  #4534
Trader Rating: 25 (100%+)
True story...i was sitting across for him. Took his advice and had the same result.
kerby is offline
Old 09-09-2014, 05:57 AM
  #4535
Machined I believe.
AlderBoy is offline
Old 09-09-2014, 05:58 AM
  #4536
I believe it, just curious as to the specifics.
AlderBoy is offline
Old 09-09-2014, 06:02 AM
  #4537
Trader Rating: 149 (100%+)
Default Center Diff Help
Hey guys, I have been running the buggy on an outdoor track since I got it in may. 20/100/5. No issues with handling.
I am getting the buggy ready for an Indoor clay track. A few trips to the track and I noticed that on Hard Braking, the front just locks up and the buggy slides. Will dropping the center diff to 60k help with the braking?
skyline1015 is offline
Old 09-09-2014, 06:06 AM
  #4538
JasonR/C's Avatar
Outdoor diffs are the same as my indoor clay setup
7/100/3.
22 pin was over 170
25 pin was 160 at most after 6 minutes.
JasonR/C is offline
Old 09-09-2014, 06:33 AM
  #4539
7/100/3.
22 pin was over 170
Interesting, this goes against the recommended gearing. If it works who can argue though.
Torrance or Ty, any thoughts on this?
AlderBoy is offline
Old 09-09-2014, 08:10 AM
  #4540
JasonR/C's Avatar
I keep my break epa at max. Adjust to 75% in your esc and then adjust with ATL only after that. No need to go down in diff fluid.
JasonR/C is offline
Old 09-09-2014, 08:15 AM
  #4541
gearing is a mystery. too far off in either direction can cause a motor to run hot.
T. Deguzman is offline
Old 09-09-2014, 08:28 AM
  #4542
Super Moderator
DRTMI's Avatar
Trader Rating: 27 (100%+)
Sounds similar to 8th scale.
DRTMI is offline
Old 09-09-2014, 08:32 AM
  #4543
snwchris's Avatar
The recommended gearing on the first page shows a (23.8) pinion for 6.5, so one would assume to carry a 24T & 25T pinion.
Motor: 6.5 FDR: 10 Pinion: 23.8
I plan on running a 8.5 motor since my first trip in 4w buggy and will probably 24T-26T pinion
snwchris is offline
Old 09-09-2014, 09:03 AM
  #4544
That it is. I run a 20/21 with a 5.5 and 21/22 with a 6.5. No heat or speed issues. Maybe I should go up a couple teeth and see what happens.
AlderBoy is offline
Old 09-09-2014, 10:55 AM
  #4545
I run 21t on an Orion 5.5 and it seems to run out of steam on straights. I bought a 22t today to try and suspect I may go as high as 23t. Pleased it's not just me. Car is brilliant by the way.
sime46 is offline
