ORCA Team - VRITRA VX COMPETITON ESC
#331
Hi,
Is they are someone else who are running 17.5T Blinky with the Orca VX VRITRA ? Before, I was running a Tekin RS (very brutal but seen to have more top speed).
For now I have :
Innital brake : 30
Drag brake : 0
Brake Freq : 1k
Punch : 10
PWM : 8k (Maybe try 32k ? Does that make a big difference ?)
Motor : Novak Ballistic
For now I have :
Innital brake : 30
Drag brake : 0
Brake Freq : 1k
Punch : 10
#332
Hi,
For now I have :
Innital brake : 30
Drag brake : 0
Brake Freq : 1k
Punch : 10
For now I have :
Innital brake : 30
Drag brake : 0
Brake Freq : 1k
Punch : 10
I was able to gear my car to the point where it was too fast and needed to slow it down.. Also noticed the temps on my motor were much lower than with my old RS, I calibrated it and uploaded the 3.0 and it was perfect with default settings but I'm going to get some help with the settings when I start racing outdoors this coming Saturday.
#333
Anyone know what is the size of the thru-hole on the PCB for Battery & Motor connection ? I want to know if QTEQ connector will work on Orca VX-1.
See http://www.multiverse.jp/QTEQ/englis...rterminal.html
cheers
#334
Definitely have the wrong gearing or something!!
i'm running between 4 and 4,5 FDR.
I've run this week-end and it's was better ... I remove timing on the motor (Ballistic) and it's start to work's pretty good.
#335
( thunder power 17.5 35 degrees timing) the motor doesn't even get hot to touch but if I geared lower it would be to fast for a small track with a lot of turns...
Go up in pinion size and watch temps and you'll be a lot faster, don't go above 160-170 degrees
#336
Hey all, was just after some advice. Is it possible to use the new orca vx1 esc for 2 cell mod touring? All the parameters seem the same as the vx and the only thing I can really notice is the lower heat sink so I guess heat might be an issue. Any thoughts would be great.
#337
#338
Does this speedo have solder holes like Lrp or posts like orion R10? What does the back end of the speed control look like?
#339
#340
Team EAM
Authorized ORCA Dealers
Just want to give an update to some new Authorized ORCA dealers in the US. These are shops that are selling the ORCA products here in the US now. Any other shops interested in carrying the line can contact me as well.
Awesomeatix USA (Mike Hanulec).
Superior Hobbies, Orlando FL
Osmon Racing products. California.
Middle River Hobbies. Maryland.
Team EAM. Tennessee.
There are several others in the process of setting up accounts and getting the products in stock.
Thanks!
EA
Thanks!
EA
#343
I went to the Orca web site and I cant find the specs for each esc. It gives some detail but not motor limit or Amp output. I would like to have more details before investing in a new product.
Also more info on the interface. I hear about a chip and a usb. Do I need to buy something to program the esc? I guess i just need to call. Feels so old fashion.
#344
over 4.5 turn motors
peak curent of 720a
etc...
you will need to buy the usb link to upgrade to the 3.0 version, but i think they all come w/ that now anyway.
you will need to buy the program card to program the esc to your liking. the esc is so nice, you won't hear anyone complain about it. Very smooth, easy to program w/ card, no need for computer.
#345
On another note, on my way to the track this morning I spilled my 20oz coffee while driving, with my car on the passenger seat and you know the rest. Thought it was going to be out of service but I plugged it in and it was fine ( smells like coffee though). Because it works after literally getting soaked in coffee, I will buy another just to have
