Inspire us. Show me your BEST, CLEANEST electronics installation pics.
#241
Here's a couple of pics of my 12th car. I am still using a brushed setup, which makes the wiring job easy, although you'll notice on one of the pics that I made an upper pod plate and cross brace that uses only 1 damper tube. That makes the motor wires a little bit more tricky to look neat as you have to wire them between the end of the cells and under the cross brace. I will get a brushless setup at some point but no need to at the moment as my car goes fine as it is! All the best guys, Chris.
#242
Wow thats very nice. You have so much space to play with tho. The electrics on mine are neet but are very close together. What reciever is that ? I have a novak 13.5 and the sensor lead snapped at the speedo end. SOO i had to cut the sensor wire and solder another bit of sensor lead to it. It was very time consuming but i did it. And i shortened it at the same time. Just gets rid of some of that unwanted sensor lead.
#243
#244
#245
My wiring.
Here is the pic i posted of my cyclone on the previous page.
I have made a few adjustments to my electronics instalation since then. I have moved my ESC closer to the motor which gives me room to put my reciever down on its bottom and i have have shortened my ESC and servo leads. I have also polished up my Novak motor. And put on a black antenna . A good tip for an old looking novak motor. I polished it up with T-Cut which is a car scratch remover type polish and it came up like chrome. I just need a low profile servo now so i can mount my pt and switch to the side of that, Heres the new install.
Find more pics of my old install on previous page and compare them !
I want to know which instalation looks neater to you guys ?
#247
thanks
thanks mate !
if you have any questions on how ive done things that your not sure of let me know on here or pm me.
#248
That looks like an LRP speedo .. but its red... someone care to tell me wtf sup witk that ?
#249
#250
esc
yes the pic of the esc is a nosram one. I am in the UK so the nosram ones ar e popular here although alot have the lrp one. RED IS BETTER lol
#251
#252
Pretty simple really .. Its called heat shrink. And a deans just looks like a toy connector. The Barrels have more surface area and no plastic.... other than the heat shrink.
#253
I'll play
My Mini
My Mini
#254
