TLR 8IGHT E 3.0 THREAD
#2659
Maddog, whats your setup for indoors? 1900?
#2660
Hi tbullard,
I agree that all servos have not the same dimensions, but you can't say "bigger than the servos usually used". I have a servo usually used, a Futaba S9352HV, and dimensions are 41mm x 21mm x 37mm.
I can say it's a little bit hard to place this servo.
And I'm not talking about the servo wires...the way you have to bent them... I drilled the receiver/servo box with a dremel to fix it.
In my opinion, the servo/receiver box is not well designed, many servos are bigger than 40.3mm (because here the problem is the lenght).
But there are many "bizarre" parts on this Losi, the way they are designed is surprising.
Bye !
Bye !
#2662
#2664
I have one of these coming in by Friday .....
A couple questions...
..... What's a recommended top of the line servo??
..... Is the steel spur a direct fit??? Just asking cause on my friends converted 8t he had to do a lil mod in order to use the nitro gear.
...... N lastly....I wanna pimp the sumbich out....Any nice hop hops available for this thing?? I haven't seen too many in my searches..
#2666
-45t is a direct fit. The truggy your buddy probably used a 48t and yes that requires at least 2mm shims under the center uprights.
-essentials: agama 43t steel spur or 44t/45t losi steel gear, aluminum servo saver top, aluminum top plate, aluminum horn, x-ring orings if they do not come with the vehicle.
-nice to have: 8 hole 1.3 pistons(non-tapered), 8 hole splits 1.2/1.4(non-tapered).
Anything else is not needed.
#2668
I have a semi related question for you all. I am looking to purchase a new e 3.0. Do I take a chance and wait until after Xmas for any after holiday sales that may come up or just go ahead and take the 10% off that some sites have going right now?
