Kyosho Ultima RB6 & RB6.6 Car Thread
#7546
69/33 with the reedy motor at 40* timing
#7550
I'm just running the kimbrough spurs with ae pads. But I have recently picked up a set of gariodisks and I have 2 days on them so far. No glazing and consistent throughout the pack. More testing required tho.
#7556
I like the stock slipper with the with the KYOUM572 SP2 WC set up.
This is a replacement Kyosho Slipper Spring Set, and is intended for use with the Kyosho Ultima RB5 SP2 WC and SC-R SP 1/10 scale vehicles. This slipper spring set allows finer slipper adjustments for more traction and consistent slipper operation. This set up is the shit . I tried the avid with the avid top shaft and it only lasted one pack it was loud that's might be just my experience.
#7558
With the apex1, you would gear your TC for a medium sized average track at 3.75 to 3.85, give or take. With the apex2 (torque/torque), same endbell timing, we are gearing between 3.5 and 3.4!!! Taller than 21.5 guys.
For the buggy, I will probably run 60 timing, 66spur, and 32-33 pinion to start. (in not exactly sure yet)
All of this changes of course if you are running the RPM stator, and/or a different rotor.
#7559
Moderator
Trader Rating: 470 (100%+)
#7560
Those suspension holders allow you to adjust width and/or toe-in. Anti-squat is still adjusted via shims under the hangers. I put them on my car a few weeks ago and cannot fault their fit & finish at all. Here's a bit more information here. If I get time in the next few days I'll scan in the eccentrics chart they provide with the hangers.
Good luck with the new RB6.
Just looked up the zx5 ones on petitrc and I think I got a handle on it, but still not 100% sure
