Losi XXX-S
Re: ONE WAY
Originally posted by Poppa Ray
Ok guys, here's the challeng I'd like to find a US supplier of an aluminum or steel (preferably aluminum) one way out drive for my one way. It would seem as though no one makes this or sells this in the US and I don't know why. mine are practically ripping aprt from use in a 19t class I don't know how the pros can do it in open mod unless they're getting that one-way from Japan. any one have any suggestions?
same here
you must have a problem somewhere from the wheel to the outdrives
also, are you running it on carpet or asphalt
ONE WAY
I'm running on a massive asphalt outdoodr track in ne FL http://www.angelfire.com/music5/g_ramos/home.html the setup has changed from what is on the site but it's still huge with killer sweepers and some TIGHT 180*s so i've got to deal with a little bit of everything.
how easy/hard to you guys think it would be to convert the XXX-S to a XXX-4. It seems like alls you would need is new arms, wheels, shock towers, body, and some different gearing.
just my .02 but for what you could buy a used xxx4 for, it would make it seem like a lot of work
Is anyone out there racing the XXX-S in Scotland?
There is a few of us What do you need to know??? And I will try to help.
I need to go to Edinburgh in the next week or two for business.
Understand there is racing close by in Penicuik using a gym's hard wood floor on Monday nights. After reading their rules, I am not too sure about what is used for tires (rubber or foam) on a stock touring (saloon) car. If it's rubber, do you know what hardness works on that flooring?
Hi Bryan,
Hi Bryan,
Originally posted by HarshGuy
Saweett ..I was just kidding with my last comment
You and STLNLST are the ultimate kidders on this board...
What's this mod I am hearing about using TC3 hubs to widen the xxx-s? What's needed?
Ball cups
Hi, i have a problem on my xxx-s.
What kind of ball cups do i put in place of originals to reduce loose linkages??
What i noticed is that the guys who runs with xxx-s use white or red ball cups, are they made from what company?? losi??
and if possible, send me the product code.
Thanks a lot.
Marcelo.
Thanks a lot.
Marcelo.
Re: Ball cups
Thanks a lot.
Marcelo.
Thanks a lot.
Marcelo.
http://www.rpmrcproducts.com/products/losi/steering.htm
or even better is
http://www.shopatron.com/product/pro...954.1955.0.0.0
