Like Tree485Likes
Yokomo YZ-2
    Hide Wikipost
Old 11-11-2021, 01:35 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-2
Last edit by: lexusbest
Welcome to the YZ2 Wiki!
Features for the lastest specification YZ-2DTM3.1
  • Long specification for dirt Main chassis Inheriting the chassis cut of dirt specification, it is longer with the same wheelbase as CAL3.
  • Aluminum front suspension mount.
  • Z2-DTM2B F2 body.
  • JConcepts ASTRO High Clearance 7inch Wing.
Features for the lastest specification YZ-2CAL3.1
  • Long specification main chassis for carpets. Long wheelbase that enables even higher speeds.
  • Steel front suspension mount.
  • Z2-DTMBL S2 Lightweight body.
  • Z2-CAL2W LMR Wing.
Common features for the lastest specification YZ-2DTM3.1 / YZ-2CAL3.1
  • The conventional position and the position of the suspension arm pin 1 mm higher can be selected on the front and back of the front suspension mount.
  • Bulkhead integrated side plate with increased rigidity.
  • The kingpin position has been changed with the new steering hub carrier, the axle position has been lengthened by 1 mm, and a steering stopper has also been added.
  • Battery holder that is easy to adjust according to the height of the battery.
  • Separate the rear mount base and upper arm holder to increase the flex around the rear and improve traction.
  • Z2-018-5 5-hole shock mounting specification Rear shock tower.
  • S4-S1S 3.0mm shaft specification front shock.
  • S4-S1M 3.0mm shaft specification rear short shock.
  • S4-008R5B L5 / LD Rear suspension arm (Φ3.5 pin).
  • Z2-01069 Rear universal shaft (69mm bone).
Setup Sheets can be found here
DT CA DTM parts comparison
YZ2T Tranny Conversion List
YOKZ2-300RFT
YOKZ2-302CT
YOKZ2-302T
YOKZ2-304T
YOKZ2-503I
YOKZ2-0023
CAL3 manual
DTM3 manual
Print Wikipost
Old 06-02-2016, 11:14 AM
  #2251
Originally Posted by wstuart
Ive got the old yz2 4 gear that i race in 17.5 on high bite clay. I havnt raced in a year. I loved the car but wanted just a little more forward bite. Will the 3 gear give me that extra forward bite?
I drove my buddies dt tonight. Had great grip but didnt quite have the corner speed im used to.
The physics suggests, yes, you would get more forward momentum, however if its the wheels spinning thats causing poor forward bite, it wont help. The trouble is that it will be such a small difference it would be hard to detect especially run 17.5.
Piles is offline
Old 06-02-2016, 11:31 AM
  #2252
Team Tekin
Randy_Pike's Avatar
It can help. The trick on the "old" car is to run softer rear springs to allow the weight to transfer while you get on the gas. Too often I see cars that don't move at all. I was running as low as a 1.8 lb spring in the rear.
High bite clay is also where I race, so take a look at my latest Yz2 3 gear setup.
Randy_Pike is offline
Old 06-02-2016, 07:06 PM
  #2253
JAE
Trader Rating: 30 (100%+)
Randy - what is your front spring rate and weight oil you are using front and rear? Thx
JAE is offline
Old 06-02-2016, 11:15 PM
  #2254
kempower2000's Avatar
If you buy the 3 gear DT version car, yes! If you buy the 3 gear CA car, no, I guess it will be even worse than the old 4 gear car then.
If the grip is there, the corner speed can be dialed in.
kempower2000 is offline
Old 06-02-2016, 11:29 PM
  #2255
WillS's Avatar
Trader Rating: 32 (100%+)
MM3 – Mid Motor, 3-Gear
This was the first orientation for most early Mid Motor conversions. It is still suitable for cars running on a high grip surface eg. artificial turf and carpet style tracks.
The rotation of the motor is in the opposite direction to the rotation of the wheels. The torque of the motor is in opposition to the rotation of the motor and is ‘aimed’ in front of the motor. This causes the rear end to squat very little under acceleration and provides very little mechanical grip unless there is already sufficient grip from the tyres. Thus forward traction is not as high as MM4. The car’s weight distribution is also more biased towards the front than in RM configurations. The car will also tend to jump with a more level attitude than in RM configurations.
WillS is offline
Old 06-03-2016, 03:29 PM
  #2256
Apologies if this has been asked before...
I just ordered the DT to run at my local track, SDRC. A lot of people seem to be doing the lay down transmissions in the B5 and Losi 3.0. Can the CA lay down transmission be installed in the DT? If so, what parts are needed?
Thanks!
rbk1115 is offline
Old 06-03-2016, 07:31 PM
  #2257
SAMCRO's Avatar
That is correct. Four gear will always have more grip than three. The weight transfer is to the rear with four gear on power
SAMCRO is offline
Old 06-08-2016, 03:22 AM
  #2258
HYPA's Avatar
I've just bought a used original YZ-2 and I've been searching the thread for setup info. I'm already planning to get a ball diff to run on clay and the machined shock pistons. Anything else to consider? What gearing are people going with for 17.5t Is the Exotek direct spur mount a good upgrade for 17.5t? Thanks.
HYPA is offline
Old 06-08-2016, 09:13 AM
  #2259
Team Tekin
Randy_Pike's Avatar
Check it out.
Attached Thumbnails Yokomo YZ-2-randy-pike-yz2-3-gear-track-time-hobies-setup.jpg
Old 06-08-2016, 09:15 AM
  #2260
Team Tekin
Randy_Pike's Avatar
Thanks!
IT should be able to, yes. You'll need the trans, idler, shock tower, and shock tower spacer I believe.
Old 06-08-2016, 09:17 AM
  #2261
Team Tekin
Randy_Pike's Avatar
I'd suggest a few sets of the Yatabe springs to be ready to adjust to your track conditions.
I run the Factory RC Avid/Sheele slipper eliminator on mine and it works well in 17.5 no issue.
Old 06-08-2016, 04:17 PM
  #2262
HYPA's Avatar
Thanks! I was looking at the Kyosho springs but damn they're expensive. Anyone know what Yokomo spring is similar to the Kyosho white?
HYPA is offline
Old 06-08-2016, 06:10 PM
  #2263
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
I believe it is Orange.
Kraig is offline
Old 06-08-2016, 06:32 PM
  #2264
Team Tekin
Randy_Pike's Avatar
Kraig is correct
Old 06-08-2016, 09:13 PM
  #2265
HYPA's Avatar
Thanks. Is there any reason why I should go for the Kyosho over the Yok/AE springs? Are they worth the cost?
HYPA is offline
