3 in 1 oil question >
3 in 1 oil question
Like Tree1Likes
3 in 1 oil question
Old 09-30-2010, 07:28 AM
  #31
I have a home brew of marvel,air tool oil,tranny fluid " any one should be fine"& 50% wd 40 that you get in the gallon. I use 2-3 times as much as ARO to flush well it doesn't stall the motor or hammer plug ,because of over compression, Started using the wd cause the oil was too hard for my daughter to pull over we first pull start RC motor with ARO. I use same in boats they get drowned. I use the pure ARO for long term storage. Always thru the carb never remove plug on my off road when after running"DIRT".
153stars is offline
Old 09-30-2010, 08:52 AM
  #32
Trader Rating: 19 (100%+)
I don't beleive in running a motor dry, it leans out the motor momentarily before it dies. Just saying.....
pooldoc is offline
Old 09-30-2010, 09:05 AM
  #33
bad ass's Avatar
Trader Rating: 7 (89%+)
can I use wd-40??
bad ass is offline
Old 09-30-2010, 09:15 AM
  #34
Originally Posted by bad ass
can I use wd-40??
WD will flush out motor very well"use more" but drys up quickly twice a week driving should work great. But for $2 a qt tranny should last a life time . Marval has a nice tiny air tool oil bottle flip top disp works perfect,just the bottle worth the price.
http://www.amazon.com/Marvel-MM080R-...N%3DB000BQSYJ2
153stars is offline
Old 09-30-2010, 09:28 AM
  #35
bad ass's Avatar
ok
bad ass is offline
Old 09-30-2010, 01:40 PM
  #36
Temps don't skyrocket and there's always some lube on the parts. I know many people who have done this for years. One has done it since before I was even born on every engine and it doesn't have any issues. I'd rather burn out all the fuel than dump it out in the environment or leave it sit in the tank.
Dredd is offline
Old 09-30-2010, 01:57 PM
  #37
merdith6's Avatar
Default So true
Originally Posted by Storydude1
After run oil is a good idea if you live in a humid climate, for storage longer than a week, or peace of mind.
Marvel Mystery Oi is a great alternative.
DO NOT USE ANYTHING WITH SILICONE. It will fuse to your Glowplug and smoke it quick.
Humid climates require oil inside the engine after a day of running, no matter how long you store it.....
merdith6 is offline
Old 09-30-2010, 02:15 PM
  #38
South Florida sure counts as humid.
Dredd is offline
Old 09-30-2010, 02:36 PM
  #39
Originally Posted by Bighomedog11
Thanks for all the great replys..
But my question was..
Can i use 2 in 1 to oil my engine? I have a 3.3 Motor
Or is tranny fluid better to use?
Why not getting a bottle of afterrun?
Tonight I have bought 2 bottles Tornado Afterrun and did cost me just a little bit less than 3 euro a bottle, it isn't the cost.....
Roelof is online now
Old 09-30-2010, 03:27 PM
  #40
blis's Avatar
umm i think i will stick to the 3 in 1.
Unless somebody eles quotes on what you say.. Never heard of anybody using tranny fluid.
Get a piece of steel, scrub it of rust and get it shining, pour a little fuel on one area, and then add a couple of drops of the oil u plan to use on the fuel and on some bare metal
Leave it over night and check to see if the oil reacted with the fuel in an adverse way and or reacted with metal. Leave it longer to see if it protects from rust.
blis is offline
Old 10-02-2010, 06:28 AM
  #41
Locum51's Avatar
Trader Rating: 12 (100%+)
I'll back up the full synthetic tranny fluid, (although i used castrol)
I dipped one corner of a paper towel in the bottle until about 1 in is saturated....then just use that corner to wipe around the sleeve and on top of the piston. Just rotate the whole assembly a couple of times and your set. *This might not be the best idea but it works.*
*It's kind of similar to coating a cylinder block after a engine rebuild.
Locum51 is offline
Old 10-02-2010, 06:51 AM
  #42
That works except I use cheese cloth as it's non abrasive(I'm sort of weird that way). We use it when we are working with film in the graphic arts industry. It doesn't scratch the emulsion when cleaning the mylar.
Dredd is offline
Old 10-02-2010, 10:18 AM
  #43
Locum51's Avatar
Yea, that's understandable.
Locum51 is offline
