Lab C-02
#376
Big Bore membrane problem + preload
Dear all,
i have a problem with the big bore membrane getting deformed (like reversed bubble) and wont go back to its original state. Any one with the same problem.. I am running 4mm preload with a 1mm hole drilled on the upper cap for a smoother ride in our bumby track.
#377
Dear all,
Also when building the shocks it is important to make sure the membrane is centered very well. I try to make sure when I tighten the cap I spin the plastic part so that the membrane stays centered.
Let me know how things go and good luck. I am not sure but I think there may also be an updated membrane that fits the big bore shock a little better in the center of the body.
DJ Apolaro
#378
It may be possible that you are hitting the membrane when the shock is fully compressed. It should not really ever, but maybe that is what is going on. Make sure that on the fronts, you have the plastic ball ends tightened completely, so the shaft does not go all the way up and the piston sits more in the middle of the body. Depending on the rear and the way you use it, you may have to monitor this as well.
DJ Apolaro
DJ Apolaro
#379
Can someone post a setup for fort myers using big bore shocks as a starting point?
#380
I will post what I am going to use for a starting point set up later today.
See ya there in about a month,
DJ Apolaro
#381
I would run your normal set up and make the shocks with 1 hole front and 2 hole rear. use 50 wt oil in the front and 55 rear. 4.6 front spring and 3.9 or 3.8 rear spring. Start with them laying down. If you run the rear extensions then go 1 up.
DJ Apolaro
DJ Apolaro
#382
can someone post the black edition manual?
#386
Hi guys,
New to on road nitro. Thinking of picking up the lab c02 black edition. I found a seller on ebay selling it for 669USD shipped. Is that a good deal on the car? Also is there a new one coming out soon? Not familiar with product releases in onroad since mostly an offroad racer. Xray is coming out with the 2014 but I am staying away from xray since parts are too expensive (and I break xrays as well ). Who will be selling parts in the USA? Acorn racing/speedworld (my LHS) won't carry them anymore so I might have to settle on the xray but I do love the LAB cars.
-Alok
-Alok
#387
The new importer for the USA is www.capamericarc.com
They have everything you may need and a live website. If there is something you are looking for, you can always email them for help. I am working with them on doing videos and they are very involved in the race community.
you can also check them out on www.facebook.com/capricornamerica
Good luck and I am sure you will love the car. It is second to none!!
DJ Apolaro
DJ Apolaro
#388
Black Edition linkage plastic parts
Hi there
Is it possible that the white plastic parts for the linkages are missing?
There are just the white parts for the shocks included.
#390
Chassis weights
Hi can someone tell me if the brass chassis weights effect the handling of the car. or are they just to bring the car up to weight. Some other brands have a sliding weight they claim by moving it back gives more steering. does our weights have the same effect. I never use mine because the car is already over weight Thanks in advance
