Tamiya Ta06
#1996
I don't seem to have the luck with my 1.5mm wrench. It cannot fit into the screw. Now I am looking to see if they have the Phillips version of that. Do you guys have any suggestion in an alternative screw that can be purchased?
#1999
does anyone know where I can purchase the wheels that come with the ta06 pro kit, there are no part numbers and the only option I have found are black, where can I get the 6 spoke wheels in grey, or silver, thanks
#2000
The Pro manual shows part number 10445976. Typing that number in on Tamiya's site it comes up with part number 58297 with #0445976 showing as the item number....
#2002
Trader Rating: 89 (100%+)
#2004
unbalance drool
Hi,
Tired to set my drool again and notice my drool is not balance when screw out the drool screw. rear is showing 1 on both side and front is showing left 2 and right 3.
Wonder why is it so. I had took out my suspension for rear and front suspension, ifs before i set. I had also took out the sway bar too.
if i were to set my drool at 5, wonder do i need to offset it for instance. if default shows 2, i will set to 7, if default shows 1 i will set it to 6.
thank you.
thank you.
#2005
Hi,
thank you.
thank you.
#2006
hi built my ta06 pro and when I went to run it it has a tendency to torque steer to the right, I built it with the ifs setup and i tried to adjust the droop, the amount of preload on the shocks, all the obious things were checked and adjusted, I also changed the shocks from left to right etc, and nothing it keeps torque steering to the right please help thanks
#2007
#2008
Double check your spring pre-load.....by picking up the center-line of the chassis with a screwdriver, and watching that both tires lift at the same time. If they lift off the surface at different times, adjust the opposite end of the car's shocks.
Turn the car around, and repeat.
#2009
I experienced the same thing at first I found since the belts are new
and tight and the rear power is almost direct drive out of the gear box
the car was snappy loose like that. I suggest turning down the throttle atv and letting the belts wear in and it should go away , could also be just a rear traction issue might be getting to much rear traction but i do not think that is the issue. As this car has awesome power out of the corner = great corner exit speed !
Best,
John
#2010
took the car apart and will try again, but what I could not undertand even when I swaped the shocks left to right the car still torque steered to the right, droop is even from left to right etc, I am at a loss to understand this car, my 417x is amazing, my ta05 ver ii with ifs and exotek chassis is even faster, but this car is not working how I want it to
