Tamiya TB Evo 6
#2462
Thanks..... I feel that the high grip surfaces slow my car down to a crawl at three degree rear toe....
Not quite, but on high grip carpet or asphalt .5 degrees rear toe works great. Never tried 0 degrees but will do so just to see how it feels compared to .5 degrees.
If conditions change and the car loosens up a bit I first experiment with different rear wings. This is on a GT10 or USGT body where a low or high down force wing can give just the right amount of rear stability and maintain that nice rotation through the turns that shaft drive cars seem to deliver. I usually keep around 4-5 different wings of varying DF. I also run a ball diff which allows for a wide variety of tightness to get that rear end working to perfection.
#2463
Trader Rating: 102 (100%+)
#2464
Help please.
Want to convert an Exo6 from 64 to 48 pitch gearing, who makes a 48 pitch spur for the evo6, and where to start on spur pinion for 17.5 blinky, For Tamiya track.
#2465
I use 66 or 60 teeth Robinson Racing for small tracks. FDR really depends of track and rules. On small ones I use 4.5-5.0 FDR on big one less than 4. In our blinky mode timing on the motor could be changed.
#2466
#2468
#2471
Like I suspected, the suspension always added another 0.5 to 1 degree toe in the rear even with the same arm mounts front and rear... Most stock setups with 2 degrees were actually 3 degrees or more, scrubbing speed, etc....
#2473
What shock towers are you using with them?
#2474
You can use either the SMJ short springs, progressive, or the Xray springs, both the linear and progressive. I use progressives in the front and linear in the back. I play around with both kinds and sometimes run both brands on the car (SMJ front/ Xray rear) All depends on grip levels of the track.
#2475
