Awesomatix EP Touring Car (A700 Shaft Drive) >
Like Tree143Likes
Old 05-02-2017, 03:22 AM
  #9466
Drift_Buggy's Avatar
Trader Rating: 22 (100%+)
Originally Posted by hanulec
I'd say yes, for most items
The challenge may be that dealers will have to special order s part if their inventory doesn't have it
Thanks, still deciding to get one or just get the A800. Be mainly for local club racing.
Drift_Buggy is offline
Old 05-02-2017, 04:14 AM
  #9467
Originally Posted by Drift_Buggy
Are parts still easy to obtain with the A700?
Even the latest versions of A700 kits are available still:
A700L2 1/10 Electric Touring Car ? AWESOMATIX
A700 Evo IIC 1/10 Electric Touring Car ( carbon chassis version) ? AWESOMATIX
A700 Evo II 1/10 Electric Touring Car ? AWESOMATIX
Drift_Buggy likes this.
Oleg Babich is offline
Old 05-02-2017, 06:45 AM
  #9468
chiefj48's Avatar
Default Evo
I have a NIB EVO kit for sale
If interested please PM me
chiefj48 is offline
Old 05-06-2017, 09:43 AM
  #9469
Trader Rating: 38 (92%+)
I'm running a a700 evo on a black crc carpet small to medium size
I'm used to running X-ray t4 with 96 spur gears. I received this a700 and had a much smaller spur gear. Should I still put a 96 spur gear in and be at 3.84 fdr ?? Using a tsr 25.5
Rcforlife13 is offline
Old 05-06-2017, 10:03 AM
  #9470
Trader Rating: 40 (100%+)
96 would be too big to get the ratio you need. Use something in the low 80 and you should be able to get the proper fdr from 17.5 to 25.5.
joech is offline
Old 05-06-2017, 01:06 PM
  #9471
hanulec's Avatar
Trader Rating: 28 (100%+)
76t to 80t was popular back in the day..
the internal ratio is 2.08 on the shaft drive car..
hanulec is offline
Old 05-06-2017, 06:43 PM
  #9472
Ur the gear ratio app on my phone says I can achieve 3.80 fdr with a 96 and 52 tooth pinion but your telling me to stick to a 80 tooth and 43 pinion for the same fdr of 3.80
Old 05-06-2017, 06:45 PM
  #9473
hanulec's Avatar
this wont fit -- that pinion is WAY TO BIG to mesh into a A700
look at the back of a manual. this will show you the gears that are designed to fit.
hanulec is offline
Old 05-06-2017, 07:20 PM
  #9474
Thank u
Old 05-06-2017, 11:10 PM
  #9475
So I have an a700 evo and a800xa Which is best for vta never ran either yet.
Old 05-06-2017, 11:54 PM
  #9476
Last question front diff or front spool in vta black carpet ?
Old 05-07-2017, 04:49 AM
  #9477
howardcano's Avatar
Trader Rating: 37 (100%+)
I find that the front diff is an absolute necessity for VTA to prevent scrubbing off speed at mid-corner and in sweepers. There's not enough horsepower to worry about spinning up the inside front wheel.
I'm currently running 50K oil in front, lube only in rear.
josecarlo1129 likes this.
howardcano is offline
Old 05-07-2017, 08:05 AM
  #9478
Trader Rating: 33 (97%+)
I was running a 49T pinion with a Novak 25.5T in VTA on a medium size outdoor asphalt track, that was a very competitive setup for it in that condition.
billdelong is offline
Old 05-07-2017, 05:44 PM
  #9479
What spur
Old 05-07-2017, 06:22 PM
  #9480
What spur
Been too long since I touched it, you've got the car now. If I had to guess, maybe an 80T because I have more of those than any other spare gear in my pit box.
