Yokomo YZ-4
#1366
It is also much stronger and secures the inge pin brace better as well.
#1367
Sorry to bring up an old post. Did you pinpoint the cause of the binding? I bought a used YZ4 and it has me a bit stumped as to why I have sooooo much of a bind. I've replaced the centre layshaft and pulley, added the narrow rear belt and used the rear belt pulley on the front. I'm at the stage of wondering if the chassis itself is tweaked.
Its always best when buying a used kit to completley dismantle and rebuild it. Never know what someone else has done to it.
#1368
Check and make sure the correct screws are in the lower bulkhead. I have seen too long of a screw protruding into the diff case and binding the gears.
#1370
#1372
#1373
#1374
Stock astro turf
Hey guys anyone have a killa stock setup 17.5t blinky mode for astro turf.i have schumacher mini spike rear plus ordering schumacher wide stagger for front. Would be awesome if you guys could help another yz4er out
#1375
Sounds like Lee Martin wasn't really happy with the YZ4 in the EOS at Hudy Arena. Something about landing off the jumps. Anyone experienced it?
I am guessing he can't gas it immediately after landing a big jump...
#1376
I have not had this issue and have not heard of anyone having this issue however that does not mean some issue arose causing the problem. Lee has had some big wins and great finishes with the YZ4 both on carpet and dirt. EOS last year he was on fire as well as grabbing 2nd at last years Euros in Valladois, Spain (large out door bumpy dirt track combined with carpet). Possibly the issue was do to using the protype shorter chassis (front half I heard was shorter) thus heard larger pulleys are used in this prototype, however I am not certain. Guess will find out what was the cause of the problem here soon.) Could be a bunch of potential issues that causing the problem. Definetly not am existing issue with the YZ4 at least one that I have not experienced nor anyone else I know whom runs the YZ4 has ever mentioned.
#1377
Possibly it was something to do with the slipper, they were losing time to the XRAY coming out of corners & did something with the slipper to help that. Lee said that then "caused other issues".
Possibly had it too tight & with the high grip carpet, punching the throttle on landings, probably upset the car.
#1378
#1380
yeah probably. I mean 5T motors gotta be wheelie machines (which is what mine has when it used to run carpet).
Maybe some guys who went to the EOS can also chime in
