MurfDogg Motor Works Discussion thread
#1201
#1202
I answered on the thred here:
http://www.rctech.net/forum/electric...l#post10445419
I love the typo of my name... Murfgod....LOL!
There is a + and - molded onto the cases... but yes, Cameron is right.
#1203
Had an awesome time at CRC's Meltdown! 83 entries.
Swapped out the boosted 17.5 MurfDogg for a Blinky 13.5 MurfDogg (rules).
Qualified 7th in Pro2. Had a good run with the 13.5 and finished 5th.
#1204
#1206
Murfdogg Products used at the 4th round, 2012 El Paso, TX Points Season Onroad Race. Murfdogg 10.5T Synergy, 5500mAh Supercharger Battery, and Octane Booster performed flawlessly throughout 6 qualifiers and a 10 min A-Main. Had to settle for second place finnish, due to own driving mistake, but retained points series lead. Thanks Matt, for such quality products that provide fantastic performance!!!
#1207
Murfdogg products performed flawlessly at race #5 of the 2012 El Paso, TX Points Season Onroad Race this past weekend using (10.5T Synergy, 5500-65c Supercharger Battery, and Octane Booster). Drivers took 2nd and 4th places in the Pro TC class, with the top 4 cars averaging 1 second seperation throughout qualifiing & 10 min AMain and continues to leads the points series! Realy appreciate the fantastic products Matt!
#1209
I believe you want to run a combo that yeilds a 7.8 FDR. Recommend confirming with Cameron Kellogg, as he dominated the 17.5 SCT class everywhere he raced.
#1211
Be smooth on the throttle and make them chase ya.
#1212
I was running an SC10 and I normally ran 75 or 78 depending on the track. FDR around 7.8 and the first time out check temps every couple of minutes to make sure you not getting the motor too hot with that gearing on your track.
#1213
Considering your running on a good sized off-road track. I have never won a race for being the fastest down the straight so I always tried to run less gear and if I could match others speed on the straight then I knew I could run faster through the infield. You don't want motor temps to get over 140 deg but you don't have to get your motor hot to run out front either.
#1214
Should be about the same. I am not sure what the Losi trans ratio is. If you have room for a 27t pinion and if the trans ratio is 2.6 the that will give you a FDR of 7.8. I think you could run around 7.5 or less with a 22t. They weight a lot less then a SC truck does.
http://www.youtube.com/watch?v=BSkO6UtKHF4
http://www.youtube.com/watch?v=GjhXnR2sM70
#1215
Murfdogg Products
Murfdogg Products performed superbly and secured top two spots on the grid at the 6th round, 2012 El Paso, TX Points Season Onroad Race. Using Murfdogg 10.5T Synergy, 5500mAh, 65c Supercharger Battery, and Octane Booster drivers TQ'ed and took both 1st and 2nd podium places during the 10 min A-Main. Murfdogg Products also bested the track record posting laps 2 tenths a lap faster than previously acheived!!! These combined products have truly enabled podium results every time out. A huge appreciation to Matt, for such quality products that provide noticably superb performance on the track!!!
