Novarossi engines thread
#5416
the cooler really don't help much in on road because of the onroad body not much airflow, also the way the modern gas tanks are made today u really don't even need a long fuel tube at all mine is direct to tank and works perfect I actually think like I said the way the tanks r today the short the better..
#5417
Mine is almost identical to yours. Total length from pressure tab to tank is what matters from I know. Not for the cooling but for foam elimination. Correct me if I'm wrong. BTW, I like your shiny pipe.
#5418
#5420
Just rub some high temp silicone grease onto the pipe before running. All the tire and fuel gunge just wipes straight off. No need for any other cleaners. Just use high temperature silicone grease!
#5421
#5422
#5423
Navarossi glow plug ?
Anyone know the differences between these #8's ?
C8TGFB
C8TGHB
C8TGTB
C8TGFB
C8TGHB
C8TGTB
#5424
C8TGFB - Slightly Cooler than HB plug so better hotter ambient conditions (a bit stronger element but a little less power). Lower consumption. Easier to tune.
C8TGHB - Similar to FB but a little hotter and develops a little more power overall. Higher fuel consumption. Weaker element so tune is critical the plug wont take a slightly lean tune.
C8TGTB - Somewhere in the middle of the above 2 in temperature. Strongest plug with the best runtime. Lowest power of all 3 plugs and easiest to tune. Longest lasting.
However, Novarossi have a new plug which I am currently using which seems to be better than all 3 of the above put together. The new plug is 'CT8' and is pretty good across the board. Easy to tune and lasts a really long time.
#5425
#5427
most guys including myself we use the os plugs in the nova those things take a beating !!!! and want more !!!
#5428
Novarossi have also brought the price of plugs down as well (finally) making them also cheaper than O.S. plugs now.
#5429
I tried the ones recommended for my mito and was same shit for a month in the beginning of the summer went throu like 10 of them went to os used the same plug for the next 3 months lol!!! I swear !!
#5430
is it novarossi ct8 = os rp8?
thanks.
