Reflex Suspension Dynamics (RSD) TC6 Upgrades (vertical ball studs, pistons,etc)
#2146
Cristian: I'm running an old graphite losi in VTA. I've gone with a shorty lipo and moved the esc to the right side of the car to balance it better. I've changed the shocks to a set of 3racing that they sell as an upgrade for the Sakura Zero. I've lowered the weight enough that the springs are to stiff. I've been reading about what you feel about your asphault springs. I'm impressed and wondered if you had an idea which spring kit I should start with, or if there was a way to weigh the car and get an idea where to start? Right now the car is plowing on entrance, then loose, but pick the throttle up and its quite drivable. Hard on front tires, lol Chris
The Losi car is a bit wider on it's weight distribution, so my guess is something around 16-17 lbs is where you are going to want to start on the medium to high grip tracks.
Ethan, I will get on it in a little while.
On another note, the bumpers for the TC6/ XRAY T4/ and Blanks are in production. They should be ready in about 2 weeks.
Lastly, I just got notice that our XRAY T4 25/30mm Fan Mount is on its way from the factory. This little bugger is hella cool.
#2147
xxx-s
Thx Cristian, I have 25in,oz springs on it now and I was thinking something under 20 was going to be better. I had some assoc springs and they didn't fit the perches or collars. Guess I should be ordering some springs, thx Chris
#2150
After the Nats I will mess with it a little bit more.
#2152
Just want to say thanks to Christian for super service, I do have a question about the retaining clips on the V2 DCJ's , i have watched the video, but still the clips seem to fit a little loose, is this a concern ? or will they still keep the pins in place?
#2153
Which video did you see?
As for the clips, you can look at the article here.
The clips should be fairly snug, not loose. Some clips might need a little more crimping and if needed, you can even clip a little off of the large clip to crimp it further. Typically I have been running a black clip on the skinny side and small silver on the large side.
#2155
New XRAY Fan Mount
RSD099 RSD XRAY T4 Universal Fan Mount
This RSD Aluminum Universal Fan Mount is designed to be used with your XRAY T4 and T3 line of vehicles. The Fan Mount installs on the chassis hole behind or infront of the motor intended to use the XRAY OEM Motor Guard.
The fan works with most 25, 30, 35 and 40mm fans. It is designed to be held in place by ONLY 1 screw on the chassis and 1 screw on the mount. It's design is simple, light weight and it makes working on your TC much easier.
#2158
Back in Stock
Hi folks! All of our RSD DCJs are back in stock. The couplings are back as well.
We should also be receiving our new bumpers today or Monday.
On another note, if you are attending the ROAR Nats and need me to bring something for you, please try to place an order over the weekend. This way I can get it packed in along with my equipment.
I will bring some product along with me to have trackside, but it won't be much.
#2159
I like that mount. Can I make this work on the TC6.1
