Associated RC 12 R5.2 >
Like Tree24Likes
Old 08-11-2016, 05:34 AM
  #946
NomadRacer's Avatar
Originally Posted by Racermac73
For removing the big wires I've found if you take side cutters and clip the wires off close to the solder tabs it takes far less heat and time to remove what is left. Trying to remove the wires in full generates a lot of unnecessary heat on the circuit board. Once removed TQ brand 16ga wire and TQ sensor wire are perfect to the motor as they flex very easily. TQ 1000 wire to the battery.
+1
NomadRacer is offline
Old 08-14-2016, 07:00 AM
  #947
NomadRacer's Avatar
Default Xenon Side Links
Any knowledge of using these side links?
http://xenon.ocnk.net/product/499
Old 08-14-2016, 03:10 PM
  #948
They should work fine, Roche uses associated and those are a replacement for the roche
Racermac73 is offline
Old 08-14-2016, 04:48 PM
  #949
NomadRacer's Avatar
Sounds good. I have two sets of each type coming so if you want to try some, give me a shout
Old 09-03-2016, 07:50 AM
  #950
gee-dub's Avatar
Default Build Help - Binding
I am about 1/3 of the way thru assembly and having significant issues with binding. Based on a general search of this (and other) threads, below are some rctech.net take-aways I have found. Any additional input would be greatly appreciated. Thanks in advance.
Rear, Step #2 Shock Assembly: The pivot ball (#4637) has significant binding in the shock eyelet.
Rear, Step #4 - Rear Links: The rear drag links, regardless of screw adjustment, bind on both ends. I found a post recommending the Yokomo YRX links as a replacement. Is this the generally accepted solution or should I be doing something with the stock parts?
Chassis, Step #4 - Side Spring Perches: The coils seem to rub the upper guide and lower trailing link to the point a 'clicking' sound is made as the coils snap into place during compression.
Front Bulkhead, Step #4: Everything: Literally. The kingpins (greased or not greased, lightly polished with 1500 grit), the ball ends, arms. I have a fluted ream on the way to (hopefully) help with some of this. The binding is far past the point I would expect 'normal running' break-in to alleviate the situation.
Again, thanks in advance.
gee-dub is offline
Old 09-03-2016, 08:19 AM
  #951
RacinJ's Avatar
This may sound odd but it works for me. Slowly remove and reinstall the shock over the pivot ball until the binding is gone. You an also squeeze the outside of eyelet lightly with a pliers to help free it up.
Before installing the side links on the car, I install the pivot balls then tighten the screws until the the gap in the link is closed. After that I set the links aside for a day or two. Before installing the link on the car, I remove the screw completely and spread the gap with a flat screw driver. Spread the gap until the pivot ball is loose in the link.
Install the links on the car and adjust the link screws so the link moves freely without feeling loose.
Compress the spring fully onto the perch. If you fell a click in the spring, slowly turn the spring clockwise until the "clicking" stops.
Heat your reamer with a lighter and ream the pivot balls. This works for me.
If the pivots are still tight, install the pivot balls and work the kingpins around in each pivot. They'll free up nicely.
RacinJ is online now
Old 09-03-2016, 09:32 AM
  #952
It is very common for the side links on most brands of pan car to fit too tightly on their pivot balls even without any pressure being applied by their little adjusting screws. To solve this binding, you'll need a way to spread the ends if the side links slightly. Speedmerchant sells a set of tiny little o-rings that fit into the little gap and act to push the ends open just enough so that they are sloppy on the pivot balls. Then you can use the little adjuster screws to pull the gap back closed just enough to yield minimum slop but with no binding either. Instead of SM's special tiny o-rings (which are hard to find) I purchased a short length of tiny silicone fuel line from my LHS, and then I slice off my own little silicone spacers with a sharp Xacto knife. My home made silicone side link spacers cost almost nothing and yet they work like a charm to spread the side link ends just enough so that they become lose on the pivot balls......allowing me to use the tiny side link adjusting screws for their intended purpose.
vafactor is offline
Old 09-05-2016, 04:04 PM
  #953
Anyone know which chassis brace and shock mount upright used Kevin Hebert in WC-Beijing?
DomenL is offline
Old 09-05-2016, 05:43 PM
  #954
RacinJ's Avatar
It looks like a redrilled for inboard side springs, standard R5.2 cross brace and the second shock mount that came with the "Lipo" conversion kit. It is a three position shock mount for chassis mounting the antenna/ shock base. (P/N 4697)
Old 09-05-2016, 07:35 PM
  #955
JeffofSpace's Avatar
These are awesome...no bind, easy to install...super smooth operation. Was a little confused at first, but after examining how the screws attach I saw that the 'offset' is to the outside. Any theories on why the offsetting helps so much (or seemingly so)?
JeffofSpace is offline
Old 09-09-2016, 07:31 PM
  #956
Fredp1's Avatar
Trader Rating: 11 (100%+)
Kevin Hebert car at the worlds seemed to have the esc mounted forward.
Does anyone know of what the weight bias was?
What's would be an ideal weight bias front to back on low grip asphalt?
Do you run the battery across the car or in line?
Fredp1 is offline
Old 09-18-2016, 07:47 PM
  #957
gee-dub's Avatar
Still working on assembly, thanks to all for the previous tips for freeing-up binding.
Now, next question.
As built <I hope> to the instructions, the pod at full droop (if I am using that term correctly) seems to have negative droop. This is to say, if you were to look at the plane of the chassis and pod from the side, it would look something like ______ / as opposed to flat (_____ _) or even positive droop (____ \).
Is this how the kit build is supposed to be? I asked someone at the track who runs a different model, and they said to simply unscrew the shock eyelet. Assuming that is the case, how much of a downward angle should the pod typically have from an even-level plane with the chassis plate?
Thanks in advance.
gee-dub is offline
Old 09-19-2016, 07:46 PM
  #958
Now, next question.
Thanks in advance.
Fully race ready the pod should decline downwards about 1mm or like 1 or 2 percent or so (from what I understand) when chassis is lifted up. When sat down on table the car should be level. Adjust shock length (blue aluminum bit covered by spring retainer). It sounds like your shock needs to be longer to achieve this.
Old 10-12-2016, 02:59 AM
  #959
Can someone please measure the height of the front shock mount point (at the centre of the pivot ball) from the chassis? I'm making a custom shock mount for mine, but it didn't come with the original mount.
Scott_T is offline
Old 10-17-2016, 05:16 AM
  #960
Default Question about h
Hi i want to know were can buy an Asso RC125,2 kit for low price, and the store must send International because i am not from the United States .
drover is offline
