Durango DEX210 Thread >
Like Tree80Likes
Old 12-13-2011, 08:12 PM
  #2731
tomdav's Avatar
Trader Rating: 44 (100%+)
Originally Posted by Cpt.America
Ok, I found out what the squeeking was coming from in my last race... my top shaft bearing exploded. No balls left or anything... the inner race of the bearing was actually hanging out on my slipper spring. The worst part, is I have no spares!
The 5x8x2.5? Of all the things that could break I would never expect a tranny bearing. I have spares for the wheels and hubs. Looks like I need to place another order.
tomdav is offline
Old 12-13-2011, 08:14 PM
  #2732
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Yep.. the little guy that the slipper spring and it's washer sit up against. My gearbox comes apart every 3 or 4 race days, and it looked fine the last time I had it apart... I don't like sudden bearing failure! I will report if I have another go out... maybe I just had a bad bearing.
Cpt.America is offline
Old 12-13-2011, 08:19 PM
  #2733
Trader Rating: 520 (100%+)
AVID...
flame56mx is offline
Old 12-13-2011, 08:28 PM
  #2734
Originally Posted by flame56mx
AVID...
I run protek.
Old 12-14-2011, 02:27 AM
  #2735
Trader Rating: 149 (100%+)
Default Gearing
Hey guys, need a little help on gearing. I am currently running the MM3 setup on the car with and lrp 8.5t and viper ESC. Track is small and very technical. Last week, my esc wouldnt turn on after running a full battery through the car. I sent the ESC in for repair and was told that my current setup is to aggressive. Im running 81t spur with 24t pinion. After running the car for 10 min, the ESC and motor were not hot at all. I was able to touch both without any issues. My throttle epa is also turned down to 80%. What gearing would you recommend to start off with?
skyline1015 is offline
Old 12-14-2011, 02:32 AM
  #2736
Originally Posted by Yeti AS3
Got the prototype done for the rear 3/3 suspension block. We will be fitting it tonight The holes for the suspension bushing look shallow, but it is just an optical confusion lol.
Great work! I know a lot of people here in the UK could do with one of these as they have broken so many! Just a thought but It would be nice to see this part be able to take the plastic pill adjustable inserts that are for the V3 410 rear brace. Then it would be fully adjustable.
AmiSMB is offline
Old 12-14-2011, 02:33 AM
  #2737
onekiwi's Avatar
First have a look at your timing on your motor and esc, that could be set too high.
I run 87(stock?)/24 LRP and SP, I'm actually going to turn down the timing on the esc today, ran it last week and it was a little too warm after the race.
onekiwi is offline
Old 12-14-2011, 02:38 AM
  #2738
I am running a 83T/24T with a SP V3 7.5 with the stock settings on the latest firmware of a HW 120A V2.1 ESC and it is really great and does not get hot at all.
AmiSMB is offline
Old 12-14-2011, 06:41 AM
  #2739
Trader Rating: 16 (100%+)
Thumbs down
Upgrade, don't replace. I have found the Durango bearings are crap. I have had two fail, and my buddy one.
zipperfoot is offline
Old 12-14-2011, 06:48 AM
  #2740
First off get a temp gun. I have seen them for under $20. You can't go by touch. I have seen the restaurant guys set a plate down with their bare hands. When I touched it, it was HOT! Going by touch will vary from one person to the next. Also what about vents? Do you have any cut outs for air to circulate?
Old 12-14-2011, 06:49 AM
  #2741
Jmuck69's Avatar
Trader Rating: 14 (100%+)
I never installed the stock bearings when I built, used AVID instead and keep two complete set of bearings as spares.
Jmuck69 is offline
Old 12-14-2011, 06:50 AM
  #2742
Jmuck69's Avatar
Maybe a conical washer is needed to ride against the bearing instead of a flat washer?
Jmuck69 is offline
Old 12-14-2011, 07:53 AM
  #2743
Good thought.. im not sure.. Could you imagine though what would of happened if the balls in the bearing had gone INTO the gearbox instead of OUT of the gearbox when it failed?
  #2744
jurquhart's Avatar
Trader Rating: 22 (100%+)
Does avid have a kit of bearings for the 210 or did you order each individual bearing. How much did the bearings cost if you don't mind me asking? I was looking at Acer b/c they have the kit of bearings but they are like $90 which seems expensive for some bearings
jurquhart is offline
Old 12-14-2011, 07:55 AM
  #2745
If you buy from Avid or Protek, they are $1 each and work great.
