T.O.P. PHOTON EX >
T.O.P. PHOTON EX
Like Tree1Likes
T.O.P. PHOTON EX
Old 04-26-2012, 12:03 PM
  #286
nitrobeast's Avatar
Trader Rating: 46 (100%+)
Originally Posted by Jerry P
I received my box from Top today and its sitting on my desk at work. I feel an illness coming on so i may have to leave early.
The illness might have to carry into tomorrow so youll feel better by Saturday
nitrobeast is offline
Old 04-26-2012, 03:06 PM
  #287
S.Stew's Avatar
Trader Rating: 13 (100%+)
Just getting into my build...
The manual lists a 5x9x.1mm shim behind the gear diff outdrives but it wasn't in bag b...anyone else have this issue ?
Also, where should I start for diff fluid ? Large open asphalt track, good grip.
S.Stew is offline
Old 04-26-2012, 04:15 PM
  #288
E.J. Evans's Avatar
Start at 2000 CST and once the o-rings swell up a touch (probably about 2 race days), you can go down to either 1000 CST or 1500 CST.
E.J. Evans is offline
Old 04-26-2012, 04:17 PM
  #289
E.J. Evans's Avatar
I'll post my standard asphalt setup shortly.
  #290
hanulec's Avatar
Trader Rating: 28 (100%+)
Hey EJ - how do you put -0.5mm of ackerman in the car? This is what the setup sheet says.
hanulec is offline
Old 04-26-2012, 04:21 PM
  #291
E.J. Evans's Avatar
I'm sure it's a misprint and supposed to say +0.5mm. But my current setup I'm running 0mm at the bell crank. I'm sure you guys will get a lot of testing in this weekend. ;-)
Old 04-26-2012, 04:26 PM
  #292
E.J. Evans's Avatar
Default Photon Build
For those building the car, I raised my roll center +0.5mm. I used our wide shims (same shims used to widen the hing pin) opposed to the standard M3 shim.
Also when putting together the steering knuckles use locktite. I add a small dab into the threads of the steering block. You only need a small amount. If you use too much it my leak out and bind up the steering.
Old 04-26-2012, 04:30 PM
  #293
E.J. Evans's Avatar
Jerry is feeling a Tooling On Photon (TOP) Illness
Old 04-26-2012, 04:38 PM
  #294
Shop Owner
nnick's Avatar
it's a very small one. I also couldn't find it so I build it without it. Of course now that kit is ready I found them!
A friend who tried them he removed them as it was very tight. We will see, most likely it wont affect performance
I put losi 1000 and see from there
nnick is offline
Old 04-26-2012, 04:41 PM
  #295
Shop Owner
nnick's Avatar
What is the purpose of the small o-ring used to the screw for the motor?
nnick is offline
Old 04-26-2012, 06:07 PM
  #296
hanulec's Avatar
I added a bunch of 'real' pictures to http://racerlog.com/wiki/T.O.P._Photon_EX
hanulec is offline
Old 04-26-2012, 06:09 PM
  #297
hanulec's Avatar
great question -- i didn't even see this in my rush to build.
hanulec is offline
Old 04-26-2012, 06:13 PM
  #298
The small o-ring can keep the motor screw in the motor mount without motor
mr.ng is offline
Old 04-26-2012, 06:19 PM
  #299
I believe they are there to hold the screw in place while your doing motor changes, or just trying to get the bolt started into the motor.
HawaiiBob is offline
Old 04-26-2012, 06:24 PM
  #300
hanulec's Avatar
Is anyone else shocked that RCMarket doesn't have Photon EX kits yet?
hanulec is offline
