Team Associated TC4
#2566
alright well i have mainly a bone stock tc4 just with ti. outdrives.
um i want to know if you need to change the caster blocks up front for a mid size high grip track and has tight turns too. like i said im running it bone stock from the box . just want to know what are the things i need to get for that track i said.
#2567
Originally posted by LoSi xXx S
how much is the antiroll bar kit cost?
The roll bar at our store is $9.95. Here is the link if you are interested.
TC4 Antil-Roll Bar Kit
Pictures for all parts TC4 will be coming soon. Thanks for your patience everyone!
#2568
Originally posted by Jack Smash
I'm running purple up front and copper rear which is one level stiffer than what he ran. I'm am not running a front ant-roll bar. I'm thinking that purple without the bar is close to copper with the bar. I'll try his spring setup in a couple weeks when i can get to run again.
#2569
Hi, i just bought a tc4 from ebay (new in box with a few hop-ups in their original packets ) i was wondering if there is anything special you need to do when you build kit (sanding, etc )
Thanks,
Chazz
Thanks,
Chazz
#2571
Hi guys,
I've recently aquired a TC4 (the man in the red suite was nice to me ), and I've been reading up on them. The only problem seems to be the outdrives (in respect to the plastic ones that is). As far as replacing them goes, does it make more sense to get the AE steel ones, or the IRS ali ones??
Chees
Crashmaster
Chees
Crashmaster
#2572
Thanks, i'll will get some shims when it comes, don't need the graphite tub as it comes with it
Chazz
Chazz
#2574
Crashmaster... according to setup sheets on rc10.com... AE drivers Baker and Levanen use IRS aluminum outdrives.
I *assume* those guys pretty much have their pick of all available equipment... and if they like the IRS product then I *assume* it's a pretty good choice.
I've heard that the AE lightened steel outdrives aren't all that light.
#2576
Originally posted by Bob Nilsen
Gary... which outdrives were you using?
Losi 6 Deg front C-Hubs and steering blocks
Losi 0 Deg rear hub carriers
X 2.0 rear toe block
Hard front Sway Bar
Purple Springs
Graphite Component Kit.
Other than that the car is stock.
#2579
I am pretty sure the entire team ran that spring set up, and yes it does seem odd, but hey, the car was the best it has been yet...
The best AE car there was Timmy's, although he didnt make the show, his car was dailed, and he was also the only AE drivers besides I think Bob running Parma tires...... (both cars were quite good)
Jack- that looks trick, but do you have the bottom milled out so the tape sits flush like baker lol. Also another cool thing i noticed on barry's snowbirds car (which was just a chassis and arms, lol) is that he had ZERO play, i think someone was saying he glued or somehow stuck plastic baggies or something and then cut them, but I would assume after one hit the slop would return... ???
