Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 07-25-2008, 05:07 PM
  #13126
CSF0623's Avatar
Trader Rating: 12 (100%+)
Originally Posted by Hi-LowBlow
what's up Carl! yeah, I will be there tomorrow.
how about you?
Gonna try to make it a least to practice for a bit. Got to go to a family party..
CSF0623 is offline
Old 07-25-2008, 06:05 PM
  #13127
mdttb's Avatar
Ok mdttb, #75187 is now in stock.
sorry for the confusion.
Thanks but now the site has problems as you cant check out I get a error.
Runtime error in /mm5/5.00/modules/component/cmp-mv-paymentfields.mvc @ [0000000a:0000008e]: modules/component/cmp-mv-paymentfields.mv: Line 97: MvDO: Unable to open '/mm5/5.00/': Is a directory
Holy batman if it aint one thing it's another.............. any one wanna buy a used Cyclone TC
mdttb is offline
Old 07-25-2008, 06:27 PM
  #13128
shadow102's Avatar
Trader Rating: 21 (96%+)
Holy bat man if it aint one thing it's another.............. any one buy a used Cyclone TC
yeah i tried ordering some hara springs today and got the same error
shadow102 is offline
Old 07-25-2008, 11:38 PM
  #13129
STLNLST's Avatar
Trader Rating: 32 (100%+)
TOASTY!!!!!!!!!
STLNLST is offline
Old 07-25-2008, 11:47 PM
  #13130
RC MARKET's Avatar
we are instock !
RC MARKET is offline
Old 07-26-2008, 11:34 AM
  #13131
slakr's Avatar
Trader Rating: 36 (100%+)
I bought this Cyclone Front Solid Axle (Spool) for my Cyclone S
https://www.ssl-stormerhobbies.com/c...ns&pn=HOT61045
But the stock Cyclone S dogbones don't push far enough into the spool outdrives.
Are there other parts I need to put a spool in my Cyclone S?
Thanks.
slakr is offline
Old 07-26-2008, 01:52 PM
  #13132
Trader Rating: 2 (75%+)
Default Purple Screw Kit?
Hey guys!
just curious if anyone knows of a place that sells purple aluminum or titanium screw kits, im super interested in picking one up for my Cyclone
any help is appreciated
Thanks guys
-randy
JDMmonkeybear is offline
Old 07-26-2008, 03:00 PM
  #13133
CSF0623's Avatar
http://www.fastener-express.com/inde...S&Category=218
CSF0623 is offline
Old 07-26-2008, 11:39 PM
  #13134
Fixed. Sorry about the glitch.
aboyerHPI is offline
Old 07-27-2008, 12:12 AM
  #13135
Geek_Speed's Avatar
Default Driveline binding
I have a friend with a Cyclone TC, essentially new.
His driveline has a problem binding up somwhere. For about 1/2 a turn of the spur gear it is "free", then, for about 1/4 turn it is "stiff". This is of course with the pinion removed.
There is nothing visibly bent, nothing visibly rubbing, or out of alignment.
Disconnecting the front drive belt shows that the binding is somewhere in the spur to rear area. The rear diff seems "normal".
Any suggestions on how to further diagnose and solve the problem. With the resistance in his driveline, it's like he's running with a drag brake enabled all the time.
Thanks.
Geek_Speed is offline
Old 07-27-2008, 01:25 AM
  #13136
Try realigning the pulley on the centre shaft, it may be binding on the middle deck.
savageguy is offline
Old 07-27-2008, 07:29 AM
  #13137
Scott B's Avatar
Trader Rating: 47 (100%+)
Thanks.
Check to make sure there a no small rocks or debry (sp) in the pulleys (center and diff pulleys).
Scott B is offline
Old 07-27-2008, 08:02 AM
  #13138
slakr's Avatar
Thanks.
Anyone?
slakr is offline
Old 07-27-2008, 01:49 PM
  #13139
The small foam pieces that go into your outdrives for the stock diffs should be placed in the outdrives of your spool, thats what I did and I have not had any issues with it!
hope that helps
-randy
Old 07-27-2008, 02:05 PM
  #13140
karlo511's Avatar
Thanks.
check the rear pulley to make sure it's centered when assembling the rear diff. if it's off, then it will create a high and low spot causing the belt to tighten and loosen with each revolution.
karlo511 is offline
