Schumacher Corner
#3481
there is no new car that I am aware of, perhaps running changes such as the new diffs...the mission is a brilliant design. Nothing stands out as being flawed
#3482
Mission
I agree that the Mission is probabl;y the best car out there. Here, I race against, TC3's,XXX-S, Corally(X-Ray), Tamiya, Kuwada, and just about anything else that I forgot. No MATTER what track I go to, its always the same. Is that one of those Schumacher's????? How it run. ???
By the end of the race day they know. It runs circles around everything else. The only problem I have being in CT, is that there are no other Schuei's and setups are pretty much trial and error. You cant just go ask the fast guy @ the track.. But when you find the SWEET spot, watch out.
Not only are they the baddest car kit out there, but with all the cool stuff that Schumacher USA has, it is also the most wicked piece of eye candy at the track..
The Mission is definetly the way to go.
PS. Paul and Adrian are AWESOME.
#3483
Your wish is my command...
Alex's Cleveland setup sheet
Also, I fixed a few things on the editable setup sheet. Please download and save the new one over the old one. (that includes you PW)- Newest Mission setup sheet
#3485
Originally posted by markg
Cole...dont know why the kwik clips couldnt be used for wheelbase adjustment...except they may be too thick, but I'm pretty sure the dia of the upper and lower hinge pins is the same...
The kit comes with an 86 tooth spur...I notice on a lot of the setups the guys are running 92 tooth... the gearing is pretty tall with the 86 tooth spur and the 20 tooth internal gear which most prefer to run..if I remember you're running on a tight indoor track, and with the 86 spur and 20 tooth main gear you'd probably be looking at something like a 22 tooth pinion for a P2K2 stocker, or a final ratio around 7.1
Hope that helps....
Hope that helps....
I'm planning on starting out with the same overall gearing, that I'm using now. It'll probably be a starting point, since my Sport2 got a heavy transmission, compared to the Mission. By the way, I'm using P2K and spitfire for the moment.
And unfortunately, my current finansial situation, dont allow me to buy the Mission right now. Good part are, that dreams are sweet and it seems that my finansial situation are being better for a reasonably time.
#3486
Here's a potentially stupid question...
I've been using a Novak TC Speed control forever, and it still seems to be working fine...at least I don't know any difference. I'm wondering if upgrading to one of the new speedos, like the Keyence would make a noticeable difference? There are some cool new ones out there to choose from, just not sure if its worth the cash to switch. Anyone have any comparison info to share?
Thanks...
Thanks...
#3487
Fireblade, James Nguyen, or anyone else, anyone got a safe overall gear ratio for a 13X2 P-94? I haven't run the car in mod yet and have a pretty big 2 day race coming up this weekend.
#3488
For a 13double i would usually start with a 7.7 overall gear ratio. I haven't ran any p-94s but would imagine that they run somewhat like the Ti series.
#3489
Thanks James, that's better than nothing.
#3490
Try with a 16 mabe. or a 14. Those p9-4s have a lot of torq mabe a 17 or 18 if the motor takes it. What pully you running too?
#3491
Why didn't you just call me and ask?
BTW, Alex's foam carpet setup is up a few posts...
#3492
Fireblade, thanks for the info, I'm running the 20 tooth pulley.
BigDogRacing, The track is 75X50, rubber tires.
#3493
Wow, never seen this thread make it to the second page Everyone must be out racing
TOP
TOP
#3494
I know PW...us not lucky enough to go racing on sat night get an extra kick in the stomach because there is no action on these type of threads as well as no racing for us...going to a Event in OK though on sunday...will get to meet proudwinner there!
PW I did send you a PM...did not know if you got it?
Thanks,
Jeff Werner
Thanks,
Jeff Werner
#3495
Well for the second time my brother had problems with his TB01 and had to use my Mission....... and he wipped up!!!! he won the main at the local track by 6 laps..... granted there where only 7 racers, but c'mon he's only 13!!!! can't wait for the outdoor season so we can hit the big outdoor track and watch him do his thing!!!!
