T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 11-12-2010, 08:52 AM
  #6226
Default Tweak
Hi
What do you guys do to get this car tweaked, it have had a small tweak since building it but after every race day it gets more and more out of tweak i donīt have really big crashes mostly i just roll the car over, i have been racing xray before which isnīt out of tweak like top.
Is there anything special to do on the top as every thing i have done donīt work.
Regards
Martin
MartinBasse is offline
Old 11-12-2010, 09:04 AM
  #6227
jrp
jrp's Avatar
Trader Rating: 19 (100%+)
Originally Posted by MartinBasse
Hi
Regards
Martin
1) Does your car turn equal circles both directions ? i.e. are your endpoints configured ?
2) Are your shocks the same length ?
3) Is the preload on your shocks the same left to right ? ie. is both front shock collars set the same , then is both rear set the same ?
4) Is your chassis flat against the table when you take your tires and shocks off ?
jrp is offline
Old 11-12-2010, 09:05 AM
  #6228
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by TAMAK
Hey guys, I broke a front steering knuckle on my photon and took it apart. somehow I lost a kingpin collar. I bought this car used so I have a bunch of spares. However, some parts look different then other and some kingpin collars do not fit on the front C hub.
Can someone give me an idea of what parts I should get to redo the front end, so its modern to todays parts? Thanks!
You need these:
http://www.amainhobbies.com/product_...g-Pin-Collar-4
TC5 ones fit, but are a bit long, should be shaved a bit. The chubs and knuckles have not changed since the car was released, but its good to have some spares.
MikeXray is offline
Old 11-12-2010, 09:15 AM
  #6229
Default tweak
Yes
Yes
Yes
No not completly never was flat out off the box.
so i donīt know if i need a new chassis i have the 6 cell nimh that came with the kit but that is allso out of tweak.
Old 11-12-2010, 09:18 AM
  #6230
MikeXray's Avatar
Hi
Regards
Martin
If you have the lipo chassis loosen the motor protector screws before you tighten the top deck screws, mine was causing a pretty bad tweak. The wings are also a spot that will shift, try loosening them, and push the car down on a flat board and re tightening them. Replace all of your screws if you haven't, the top ones suck and will strip, better screws will help you get everything tighter.
MikeXray is offline
Old 11-12-2010, 09:27 AM
  #6231
DaveW's Avatar
IF the tweak you are talking about shows when you are using a tweak station (flat board/bubble type), tire wear will show a difference on the bubble between rounds. Some will see this as chassis tweak, when its just normal tire wear showing as the variable. (IE: A track with lots of right hand high speed corners will generally wear the left front twice as much than the right rear)
YES this even shows on rubber tire setups... but depends on how much tire wear you actually have. If the car is set up right and you have very little tire rubber showing in your body, then tire wear induced tweak should be minimal. Very little adjustment should be needed between rounds.
DaveW is offline
Old 11-12-2010, 10:38 AM
  #6232
TAMAK's Avatar
Trader Rating: 29 (100%+)
Okay.... I did some research and it looks like the car I bought had xray steering knuckles on it. as well as C hubs. . Anyways, it looks like they work, but I am in the process of putting everything back to original.
TAMAK is offline
Old 11-12-2010, 10:56 AM
  #6233
greenracing's Avatar
This car has ball diffs or it is gear diff from the factory??
greenracing is offline
Old 11-12-2010, 10:57 AM
  #6234
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
ball diff
Marcos.J is offline
Old 11-12-2010, 11:15 AM
  #6235
jrp
jrp's Avatar
Default front binding
Is there any tricks to reduce the binding in the front end at near steering lock ?
And to qualify, can anything by done with TOP parts to improving the situation ? I have read the thread about converting over to use some XRay parts.
And secondly, does anyone feel this is even an issue worth messing with ?
jrp is offline
Old 11-12-2010, 12:13 PM
  #6236
I got rid of the chatter at near lock when I went to the TOP steel universals.
DJG24 is offline
Old 11-12-2010, 01:19 PM
  #6237
haywood's Avatar
Trader Rating: 49 (100%+)
I also have this issue and I have not been able to get rid of it. Just running it!
haywood is offline
Old 11-12-2010, 01:27 PM
  #6238
RC MARKET's Avatar
Trader Rating: 12 (100%+)
Originally Posted by MikeXray
You need these:
$8.49 ?
US$3 only !
RC MARKET is offline
Old 11-12-2010, 01:57 PM
  #6239
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Originally Posted by RC MARKET
$8.49 ?
US$3 only !
don't forget the 13.54 shipping fee to usa...
OVA is offline
Old 11-12-2010, 02:05 PM
  #6240
RC MARKET's Avatar
but if group to order will had bester price !
