Ask Team Tekin
#677
Is there a way to put the speedo (RS PRO) in blinky mode from the Pit tune options?
#678
Use MODE & INCR buttons to change TP to (1)
TP is the 5th light in the sequence.
The Original instruction manual explains this in detail, though the function of TP is not what it used to be, changing the settings using the buttons has not changed.
This is with vers 208-212
http://www.teamtekin.com/hotwire_RS.html
#679
If I remember correctly from the Pro4 thread, Randy stated that the T8 and pro4 motors do not work well with much boost or turbo, and thats why the RX8 doesnt have those features. All it does is increase heat. I could be remembering incorrectly. Check the Pro4 thread. I know this was discussed though.
#680
Could anyone make suggestions on starting setup for my RS/Redline17.5.
running 12th scale. 1s, 17.5 boost. rolling out around 80mm average but getting dusted in the infield by duo3s ect.
i followed someones suggestion on our own forums for starting timing settings but those are for their trinity motors, so looking for advice using Tekin motors if possible.
I use to run one and as I remember I had to run about 8 degrees mechanical timing to get punch in the infield. If you do this, you need to take 8 degrees out of the electronic timing.
I may pull my redline out of my offroad car and play with it Sunday. If I come up with something, I'll post it here.
#681
RS
I thought I read somewhere that you can have two different profiles that you can switch between without using the hotwire. I run a 17.5 blinky class and a mod class. Is it possible to have 2 seperate profiles to switch between blinky and boosted using just the ESC buttons?
Nevermind. Just found it. skipped over page 44
#682
Does anyone know where i can get a switch for one of my tekin RS `s any help will be great .
#686
