Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread >
Like Tree35Likes
    Hide Wikipost
Old 01-24-2018, 07:02 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: alex4r
Kyosho ZX6.6 New Parts (* = required to update ZX6 to ZX6.6 platform)
LA359B - Center Mount Set (ZX6.6)*
LA375 - Center Diff. Gear Set(ZX6.6)*
LA375-01 - Center Diff. Gear Case Set(ZX6.6)
LA375-78 - Spur Gear(48P-78T/ZX6.6)
LA376 - Center Drive Shaft (71.5/ZX6.6)*
LA377 - Center Drive Shaft (79.5/ZX6.6)* (x2)
LA378 - Center Drive Shaft (88/ZX6.6)*
LA379 - Joint Cup Cover (ZX6/ZX6.6)*
LAW54B-01 - HD Chassis*
LA355B - Side guard set*
UM713B - Rear Arms (from RB6)*
UM561 - Outer rear hinge pins*
LA236-12B - 1.2mm Front sway bar*
LA351B 4-hole front shock tower*
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals
Lazer ZX6.6
Lazer ZX6
After Market Bodies
JConcepts Silencer
Weight Reduction options for 13.5 Class
Chassis:
UMW711B - Carbon composite rear arms
LAW60 - Carbon composite front upper bulkhead
LAW61 - Carbon composite rear upper bulkhead
LAW52 - Carbon composite front chassis brace
LAW53 - Carbon composite rear chassis brace
LA209HB - Carbon composite gear boxes (pinion bearing retainer & upper gearbox half only, lower half not compatible/saves 4.6g total)
Driveline:
LA211B - Plastic drive cups for center drive shafts coming out of front & rear gear boxes (requires drilling two holes for set screws to secure LA379)
TFW001 - Aluminum blade style outdrives (for ball diff/requires TF013)
LA202 - Aluminum pinion shafts (for ball diff)
TFW126 - VVC outdrives (for gear diff - front/rear/center)
TFW008 - VVC cross pins (for gear diff - front/rear/center)
Misc:
LAB06LW - LW Blade body
SK0402 - Ti screw set (Available at Lunsfordracing.com)
PTK-T-2111 - Ti screw set (cheaper, slightly less durable option)
LNS7765 - Ti ball studs
LNS2688 - Ti Turnbuckles
LNS36107 - Ti Turnbuckles (super duty)
W0201H - Hard anodized lower shock balls
1-N3024A-R - Aluminum M3x2.4 nuts (for shock standoffs)
1-N3033NA-R - Aluminum M3x3.3 locknuts
Print Wikipost
Old 07-07-2014, 09:13 PM
  #526
Thanks & Thanks
Originally Posted by vikingen
excellent choice
Originally Posted by K_King
Response.
Order placed!
Steady14 is offline
Old 07-07-2014, 10:34 PM
  #527
vikingen's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Zylux
Nice, almost exactly the layout I think I will use (even the same servo!). I think I will run the servo on the opposite side if this is an option though as the motor & esc will be heavier than my battery.
I'd be really interested to know the weight and if possible, weight distribution front / rear and left / right if you get a chance and find your scale.
Cheers,
Dom
1703g
vikingen is offline
Old 07-08-2014, 01:55 AM
  #528
Zylux's Avatar
Originally Posted by Jpm1
Hi Dom, I swapped my servo over for better balance also, just swap the steering linkage over and cut the 2 little lugs of the plastic servo tray which allows you to reverse it.
Justin
Thanks Justin, I'll do the same.
Zylux is offline
Old 07-08-2014, 01:57 AM
  #529
Zylux's Avatar
1703g
Thanks. I think with enough titanium etc we should be able to get it down closer to 1600.
What is the Roar legal weight limit for 4wd buggy? Anyone know if this applies in Australian racing?
Zylux is offline
Old 07-08-2014, 02:02 AM
  #530
Jpm1's Avatar
1613 g is the minimum in oz, I think it's only enforced at sanctioned events, to drop weight I use alloy screws, they are a lot lighter then titanium but not as strong.
Justin
Jpm1 is offline
Old 07-08-2014, 02:24 AM
  #531
Zylux's Avatar
Justin
Yeah, I thought about alloy screws but I have enough instances where the heads of even steel screws round so am reluctant to try them. Especially given how tough the Kyosho plastic seems to be. I guess aluminium screws would be about 50% lighter than steel ones vs about 30% for titanium.
I emailed MIP about the possibility of some aluminium out-drives, dog-bones etc but was informed that they have no plans to make them for the ZX6 at this stage. Unless they got a lot of interest.... come on guys!
I'm actually thinking about trying to make my own alloy drive-train bits for some fun. Just need to get my hands on a Mill... have a lathe but almost everything seems to need at least one milling operation!
Zylux is offline
Old 07-08-2014, 04:42 AM
  #532
Kyosho do light weight diff outdrives for the ZX5, diff parts are shared.
MIP do light weight shafts for the RB5/RB6 range, rear shafts shared.
Plenty of ways to get the weight out already BUT try it a as it is, unless your struggling for acceleration in stock classes then carrying a little extra weight low down only helps plant the car.
RogerM is offline
Old 07-08-2014, 04:57 AM
  #533
Zylux's Avatar
Great, thanks. I didn't realise the RB6 shafts were the same in the rear as the ZX6! Already ordered the light weight Kyosho diff out-drives.
People often say that extra weight can be good, but I'm just not a believer in "heavier is better" regardless of the conditions etc. I'll try it out as it is before I go too extreme though.
Cheers, Dom
Zylux is offline
Old 07-10-2014, 10:46 PM
  #534
Jinggoy's Avatar
Tebo & his production ZX6!
jtprc.com - sorry can't post link new to RCtech
Jinggoy is offline
Old 07-11-2014, 01:14 PM
  #535
4WDriver's Avatar
can anyone describe the difference between the ZX6 (LA371) and ZX5 FS2 (LA254) front knuckle and hub carrier parts?
Last edited by 4WDriver; 07-11-2014 at 02:02 PM. Reason: found photo of LA371 - says ZX5 on package
4WDriver is offline
Old 07-11-2014, 02:03 PM
  #536
Andy p's Avatar
The hub carrier has a little bit more material top and bottom on the "6" the king pin screws sit in a recess top and bottom
A pic might explain it abit better
This is the "6"
This is the "5"
Andy p is offline
Old 07-11-2014, 02:56 PM
  #537
ferrarieeeee's Avatar
Does anyone managed to break any part yet? Have made the pre-order and wondered what parts should I be keeping
ferrarieeeee is offline
Old 07-11-2014, 04:15 PM
  #538
biggerT's Avatar
Just front tower so far
biggerT is offline
Old 07-11-2014, 04:38 PM
  #539
mourinho's Avatar
Trader Rating: 46 (100%+)
I started building my zx6 and being my first 4 wheeler I did something pretty stupid
I was looking at the arms and thought 'gee I dont like the look of those mould points' so I snipped them all off and ignorantly carried on until I reached roughly halfway and it was time to put on the swaybars...
Waiting for new arms to arrive, nice kit though.
mourinho is offline
Old 07-11-2014, 05:37 PM
  #540
Trader Rating: 68 (100%+)
That's one beefy tower. Where did it break
Speedychris22 is offline
